09-06-2015, 07:48 AM   #1
K3 II shutter doesn't stop firing
I bought my K3-II a couple of months ago and have only taken a few hundred shots so far. Yesterday, in the course of a walk in nice weather and a the point of taking another picture, the shutter started rattling away without stopping. The camera wouldn't power off the normal way and I eventually had to remove the battery to put it to a halt. The drive mode was on Continuous (H). After refitting the battery, the camera performed normally and I have used it for another day without trouble. The serial number of my camera is 6189049, which means it may a have an issue refusing to power off, but I gather that is a different story.
Of course I find this very disturbing ! Anyone else with the same problem ?
09-06-2015, 08:42 AM   #2
enoeske's Avatar
QuoteOriginally posted by decpi Quote
I wonder if searching would turn up anything...
Do you have the latest firmware?
09-06-2015, 08:46 AM   #3
Not a Number's Avatar
There are no firmware updates for the K3ii as of yet.
If your serial number is in the service advisory range send it in for service or have it replaced by the seller if still possible.
09-06-2015, 09:09 AM   #4
Otis Memorial Pentaxian
I believe I have seen one other report of runaway shutter on the K-3II. If the camera is new, contact your seller for replacement. Otherwise, contact Ricoh for warranty service/replacement.
09-06-2015, 09:25 AM   #5
This is the so-called mirror flop issue. Just do a battery pull and hopefully it doesn't happen again, but as Steve said seek service if it turns out to be a recurring problem (i.e. not just due to bad luck/low voltage).
09-07-2015, 05:48 PM   #6
Man you are scaring me. My k-3II is coming this September. Actually I wanted an additional K-5IIs but it's no longer available. I skipped the k-3 because of this. I hope mine will be fine as I specifically asked for a camera with the serial number above what was stated by Pentax.
09-28-2017, 08:47 AM   #7
Lev
Mine did something similar couple of days ago. I was shooting macro and suddenly shutter started to fire like crazy, but it stopped shortly, I was scared to death. I was like brrrrrrr.. The camera is working perfectly since that moment but of course I wonder what it was? I think that this might be a software bug which is very hard to find in lab but rarely shows itself in real life....
09-28-2017, 08:57 AM   #8
normhead's Avatar
My K-3 did it twice after I first bought it. 3 years later it hasn't happened since.
09-28-2017, 05:35 PM   #9
QuoteOriginally posted by Lev Quote
It's a different scenario compared to the k-3. It happened to me when my k-3II was about a month old. I don't know how much was my shutter count then. What happened to me was I was shooting on single shot mode continuously. Then it started to flap as if I had my camera on continuous mode. When I released the shutter button, it stopped. It never happened since then. Not even on continuous mode. I hope it won't happen again, fingers crossed.
09-28-2017, 08:08 PM   #10
Like Norm, my K3 has done that twice in 3 years and over 60,000 shutter actuations. It hasn't happened for at least a year so I wouldn't worry about it and enjoy a great camera. The worst thing that seems happen is that you need to stop and remove the battery. The shutter-flap thing is so random and rare, I wonder if it is triggered by an unusual set of events that send the software into a loop? The second time it happened to me the camera had gone into interval mode shooting by accident or as a result of the glitsch?
09-29-2017, 01:23 PM   #11
Lev
Maybe in older versions of firmware this was uncontrolled behavior, I mean, engineers didn't know this of course. Then, when users started to complain about this issue in K3, they have just temporarily fixed this by just putting a little break function in shutter loop which triggers if the shutter fires faster than it should be. That is why in K3 II, or in K3 with newer firmware shutter stops itself without needing to remove battery. or i might be completely wrong....
09-29-2017, 06:35 PM   #12
Actually, some say it's a hardware problem. What Ricoh did was to make a software update to arrest the problem. I even thought that this hardware problem was arrested on the K-3II. I guess they still use the same hardware and made some tweaks so that the mirror flap would behave differently than that of the K-3. So far, there are very few reports of this on the k-3II.
battery, camera, course, dslr, k-3, k3, k3 ii shutter, pentax k-3, power, shutter, shutter doesn't stop
Chinon lens won't stop down on K3 BigMackCam Pentax SLR Lens Discussion 18 05-16-2015 02:28 AM
K3 doesn't report lenses in EXIF RobG Pentax K-3 17 12-06-2014 12:04 PM
Odd behaviour from Super A - aperture doesn't stop down Jonathan Mac Pentax Film SLR Discussion 15 10-21-2014 11:07 PM
ME Super - shutter doesn't fire iht Pentax Film SLR Discussion 13 09-12-2013 07:14 PM
I don't understand why stop down metering doesn't work well at higher f stops. geekette Pentax DSLR Discussion 51 06-08-2011 10:39 PM
All times are GMT -7. The time now is 09:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
