09-16-2015, 12:23 PM   #1
K-3 II noticeably slower than K-5 II shooting manual bursts
I recently got my new K-3 II. After having used its grandfather - the K-5 II - for 2 years its a very welcome improvement... especially AF-wise.
So far I'm very happy with it, its been carefully improved in so many ways without changing its character or feel.
Except there is one rather annoying problem I can't really wrap my head around:
Shooting bursts manually (e.g. firing 3 quick shots in single shot mode) feels very sluggish compared to the K-5 II.
Using the old camera I could easily reach 4 or 5 fps with nothing but my index finger. On the K-3 II it feels more like 1 or 2 fps.
Did by any chance somebody have a similar experience when upgrading from K-5 (II) to K-3 (II)?
I always loved the ability to fire a couple of shots very quickly without engaging continuous shooting mode. The K-5 felt extremely responsive for that matter...
If something seems unclear to you, please don't hesitate to ask... English is not my first language
09-16-2015, 12:43 PM   #2
Do you have a slow SD card (i.e. one that isn't UHS-I rated)? That would be the first thing I'd suspect. You should be able to reach close to the maximum framerate in optimal conditions.
09-16-2015, 01:06 PM   #3
That would make an awful lot of sense for sure. Sadly that can't be the issue as the camera reaches its 8 fps in continuous shooting mode with ease.
I tried playing around with some options too, switching to JPEG, disabling NR, lens correction and so on...
09-16-2015, 01:12 PM   #4
sholtzma's Avatar
First, your English is excellent, so no problems with communication....
What shutter speed(s) are you using when you shoot in this way? Obviously, the slower the shutter speed, the fewer shots you will be able to fire off in a second.... If you set up a situation in which the camera has a shutter speed setting of 1/500 second, say in bright light outside and with a large aperture, are you still having problems with quick shutter release in single shot mode?
09-16-2015, 01:45 PM   #5
Thank you
I think its not so much an issue of shutter speed as it will do its proclaimed 8 fps under exactly the same lighting conditions.
Just to be sure I just mounted my 50/1.8 plastic fantastic, cranked up all the lights, fixed shutter speed at 1/500 and took close up photos of the light bulb (which resulted in ISO 200 and F1.8).
The issue still remains... :-/
All experiments are conducted with AF disabled of course.
09-16-2015, 02:42 PM   #6
clostoyo's Avatar
Thank you for this information, I am in the market for a new Pentax and this helps.
09-16-2015, 03:23 PM   #7
Check that you are not in AFC, I found that it slows down fps quite a bit because it tries to reacquire focus after every shot.
09-16-2015, 05:56 PM   #8
Single shot mode doesn't use the buffer, so you won't get a second shot until it has fully dealt with the previous shot. Set to continuous low or medium, and you can bang off three shots quickly or shoot a single shot.
09-16-2015, 09:59 PM   #9
@clostoyo:
Don't get me wrong, the K-3 II is exceptionally good in every other way, except this issue annoyingly gets in the way of my shooting habits.
@derekkite:
Something like that came to my mind, too. I just couldn't figure out, why Pentax would make such a decision in software design. Have you found any sources of information to back that theory up?
If you are right, this would be an issue that could be fixed pretty easily at software level... so there is still hope
Until then, I might just try the workaround using continuous medium and low modes. The K-5's behaviour was much more comfortable though.
09-17-2015, 12:24 AM   #10
I had the same experience when going from the K-5 to the K-3. It seems to be normal for the K-3, sadly. See
https://www.pentaxforums.com/forums/172-pentax-k-3/270925-my-new-k-3-suffers-...r-penalty.html
Regards,
--Anders.
09-17-2015, 01:18 AM   #11
When I want to do a good burst job to get the best keeper rate, I combine burst mode M or H rate with shutter press with my finger. Also, someone wrote a method of AF dump, if I understood correctly, it's about half-pressing once for coarse AF (pre-AF) and then a second shutter half-press to reach the focus target.
09-17-2015, 02:49 AM   #12
amoringello's Avatar
Yes the K3 has a definite forced delay between presses.
This was discussed in another post some time ago... just cannot find it now.
It does not matter if in auto focus or manual. Ricoh crippled the button in some fashion.
Although I am sure it was to solve another issue, I am just not sure what that would be.
Anyway, Simply set up the camera to medium or high speed burst mode, and you can poke at the shutter button as fast as the shutter speed will allow. Of course this means if you accidentally hold the button too long you may get additional shots.
Not a perfect solution but I find having the camera in Medium burst mode is a decent go-between of speed and safety of accidental firings.
[edit]
ha, somehow I scrolled past asp1880's link to "My new K-3 suffers from 'early shutter penalty'.
Sorry. That is exactly the thread to which I was referring.
09-17-2015, 04:07 AM   #13
What would be be the best card to use?
09-17-2015, 04:24 AM   #14
QuoteOriginally posted by totsmuyco Quote
I use the Sandisk Extreme Pro. They are quick and reliable.
09-17-2015, 04:33 AM   #15
FOX
Can you try disabling SR to see if it improves? I have a K5 with faulty SR and because of that I disabled it, and found myself amazed at how much speedier it is taking shots, more than the K3 I had.
burst, bursts, dslr, fps, ii, k-3, k-3 ii, k-5, k-5 ii, k3, mode, pentax k-3, performance, shots, speed
Pentax K-3 II user's manual gsolti Pentax K-3 8 06-04-2015 08:44 PM
K-3 / K-5 II / K-50: Don't forget the extended warranty! Adam Pentax Price Watch 69 01-07-2015 12:56 AM
lots of different creative work- K-5, K-5 II/s, or K-3 yas_min Troubleshooting and Beginner Help 15 01-23-2014 08:05 AM
All times are GMT -7. The time now is 06:01 PM. | See also: NikonForums.com, part of our network of photo forums!
