09-21-2015, 12:43 PM   #1
K3 fault symbol
When mounting my Sigma 105mm 1:2.8 DG Macro on my K3 I get a flashing "F" in both displays. Never happened before..have had this lens for a few years. No flashing "f" with Sigma 18-200 or Pentax kit lens, 50-200 zoom or wide angle. User manual doesn't mention flashing "f" I assume it means fault, but don't know how to remedy. Any thoughts?
09-21-2015, 12:46 PM   #2
Timd's Avatar
Flashing f means it can't read the lens info. It's usually a bad contact if it is an automatic lens.
09-21-2015, 12:47 PM - 1 Like   #3
The "F--" appears when the body does not detect the "A" contact* on the mount. This happens with lenses lacking the contact (not your lens) or when the aperture ring is off the "A" setting or when there is poor contact between lens contacts and the body or when there is a fault in the lens.
So, check your aperture ring position and if on the "A" position, gently buff the contacts on both lens and body with a microfiber cloth.
* Third from the mount lock pin in the below diagram
Courtesy B. Dimitrov (http://www.bdimitrov.de/kmp/index.html)
09-21-2015, 12:58 PM   #4
QuoteOriginally posted by TomGoulding Quote
Set the aperture ring to "A" or if that's already set, try dismounting the lens, cleaning its contacts, and putting it back on.
09-21-2015, 02:40 PM   #5
Bruce Clark's Avatar
Hi I have this lens and it is not uncommon for this to occur. Solution is ensure proper contact is made by remounting the lens, resetting the aperture ring or cleaning the contacts. A bit of a nuisance at times. This is the only fault with this otherwise excellent lens
09-22-2015, 06:31 AM   #6
Fault message
Thanks to all. Turned out the lens ring somehow was moved off the A setting. Once reset all is good. Thanks again for the insightful replies. This is a great forum.
dslr, fault, k-3, k3, k3 fault symbol, lens, pentax k-3, sigma
K200D 'dead', flashing battery symbol Marbella Pete Troubleshooting and Beginner Help 7 01-15-2015 01:31 AM
Odd symbol on Q display Ribcracker Troubleshooting and Beginner Help 3 10-28-2014 07:12 PM
What is this strange symbol? lithedreamer Pentax K-30 & K-50 18 09-27-2014 08:50 AM
What's that symbol? jct us101 Photographic Technique 12 06-08-2009 06:21 PM
Copyright Symbol. NLAlston Photographic Technique 9 03-21-2007 12:14 PM
All times are GMT -7. The time now is 08:17 PM. | See also: NikonForums.com, part of our network of photo forums!
