09-28-2015, 12:46 PM   #1
bdery's Avatar
Lighting up the top LCD
Hi there,
I frequently use the top LCD to adjust settings, and I frequently shoot in the dark. Because of this, I configured the RAW button to light up the top LCD. On the K20D it used to be the EV button which lit up that screen. With the K-3 I believe there is no other option than using the RAW button as I did, but I'd love to be proven wrong.
09-28-2015, 01:23 PM   #2
If you use the status screen, turning that on should also illuminate the top LCD.
And I could swear I remember that the DOF preview button does the same, but perhaps I'm getting my camera systems mixed up.
09-28-2015, 03:26 PM   #3
mcgregni's Avatar
I'm sure that on the K7 and K5 models there's a custom setting to switch off the LCD, otherwise its default action is to illuminate whenever the status screen does (as Adam suggests). The only time I see mine come on is if I flick into green mode briefly, as the custom setting is overridden in green mode.
09-29-2015, 12:25 AM   #4
mtux's Avatar
If you revert this setting, it will light up with half press of shutter button.
By revert I mean set the RAW button to do something else.
09-29-2015, 06:54 AM   #5
bdery's Avatar
QuoteOriginally posted by mtux Quote
That's got to be extremely annoying to have it light up all the time! Plus it will drain the battery, won'T it? And When I turn the light on, I usually want to adjust something.
I never noticed it, but that would be nice. Basically pressing the INFO button?
I'd love that, I never use the DOF button anyway. More things to check tonight!
09-29-2015, 11:04 AM   #6
Half press...no not annoying at all. I have the rear status screen turned off so the only battery draw is dim back light for the top LCD.
09-29-2015, 12:44 PM   #7
Essentially, yes.
09-29-2015, 08:44 PM   #8
mtux's Avatar
No! how much battery that dim light uses comparing to the LCD or shutter mechanism? I say none!
I think if there was a way to have both of them together would be better. but even now I find it practical enough. you can choose which one you prefer.
However I remember seeing a way to set the duration of light to be on, somewhere which I didn't find in yesterday's hunt in menus.
09-30-2015, 07:37 PM   #9
I think the duration of the light is tied to the metering, no? So I think 3, 10, or 30 seconds. I could be completely wrong though...
button, dslr, k-3, k3, lcd, pentax k-3
Top-down LCD viewer - Shoot from the hip Plainfaced Pentax K-01 15 12-18-2013 11:34 AM
Does PZ1-p top LCD light up? Dennis200 Pentax Film SLR Discussion 5 05-10-2012 04:42 PM
Top LCD light on the 645D Thomas Pentax Medium Format 8 12-18-2011 06:49 AM
The missing top LCD panel mrbrightside Pentax K-r 17 12-23-2010 01:14 AM
Working without the top LCD screen? HogRider Pentax DSLR Discussion 23 10-26-2009 11:23 PM
All times are GMT -7. The time now is 12:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
