I think I've come across a problem with my K3-ll. But only with my just repaired and returned today Sigma 70-200mmF2.8 ll Macro lens is attached.
The other week, my Sigma 70-200F2.8-ll auto focus died. Just before it stoped working, while on my K3-ll I noticed that when it was at 70mm zoom, the auto focus wouldn't work. I would get a MF flashing in the view finder. If I zoomed it in just a little, between 75 and 80mm it would work. I tried it on my K20D, worked fine from 70 through to 200mm. Put it back on the K3-ll worked from 75/80mm through to 200mm fine, but not at 70mm. Then it died, stoped working all together, even on the K20D.
Sent it to Melbourne, C.R.Kennedy, Australian Pentax/Sigma. Got it back today. New 065 Rotor, new Stator ring+ Labour. $256.15. Stuck it on my K3-ll to give it a run. Guess what, Lens works, but not at 70mm zoom. Same thing as before. Works great from 75/80mm through to 200mm, but not at 70mm. Put it on the K20D, works fine from 70mm through to 200mm
Back on the K3-ll, dup. Nothing at 70mm, fine from 75/80mm.
Put it on the K20D again. Yep works fine. Put it on my K10D. Yep, works fine.
Has to be something wrong with my K3-ll, right ?? That's what I'm now thinking.
It's probably what killed the auto focus on the 70-200 in the first place. My Sigma 50-500 works fine on it, my DA*200, with and without TC works fine. But the 70-200 wont at 70mm. But will from 75/80mm up. I just don't get it.
My K3-ll is in the affected serial range for the not powering off/GPS problems. But I've had no problems, other than this with the Sigma 70-200F2.8-ll
Looks like the K3-ll is going on a holiday back to C.R.Kennedy next week..
Anyone else with a K3-ll having similar troubles with auto focus on Sigma lenses...
