07-12-2016, 07:32 PM   #31
JimJohnson's Avatar
What not to do...
I tend to use center focus and recompose (slightly and well within depth of field). If you do this you have to hold the camera in the half-press position (assuming you don't use the AF back button) until you achieve 'the moment'. It worked fine with the K-30. It doesn't work as well with my K-3. The half-press point is finer on the K-3 and if you do let go, you have to re-center on the subject, half-press, recompose and wait. Here is where it got frustrating. The camera has supposedly re-focused, but in reality you are essentially at the same focus point as before. Certainly my 18-135 hasn't budged. And when you fully press the shutter - nothing. I suspect the lens hasn't moved enough that the camera believes you have re-focused and if in focus priority release - there is no release.And you just missed 'the moment'.
So I either have to give up recomposing (hard to do as I don't trust the camera to pick the right subject, nor do I want to fiddle around selecting a focus point). Use the back AF button (will probably teach myself to do that rather than the shutter release), or what I have done - turned off focus priority shutter release. I KNOW the subject is still in focus because neither it nor I have moved.
07-12-2016, 08:58 PM   #32
clackers's Avatar
QuoteOriginally posted by JimJohnson Quote
What not to do...
Yep, back button separates the functions and means you don't need to do index finger gymnastics.
07-12-2016, 10:50 PM   #33
What not to do...
I use the back AF button set to AFC by default, I got the habit very fast honestly (1 day?) and I use off center points.
So if I need to shoot a portrait with the focus on the eye and tiny dof, I just select the AF point I need, ask the AF to do its job so there no need to recompose. I agree that the ergonomics to select that AF point are not as good as I would like, true . I hate in particular that you can eather select the focus point or select JPEG mode, burst modes, white balance etc with the same buttons.
af, af-c, camera, dof, dslr, f2.8, field, focus, k-3, k-3 technique, k3, kids, lens, light, pentax k-3, pools, practice, prints, priority, sensor, shutter, target, technique or hardware, time
A difference between K-5 and K-3 retention of aperture or shutter speed settings at p MNCurt-K10D Pentax DSLR Discussion 10 04-21-2015 03:08 PM
Upgrade from K-5 to K-3 or Fuji XT1 or Oly EM1 zVratko Pentax DSLR Discussion 34 11-01-2014 11:56 AM
Question for K-30 & K-5II (s) users (those who own both or compared them) Bernie_Rain Pentax DSLR Discussion 7 01-18-2014 01:40 PM
K-3 AF question (again or not) sinus007 Pentax K-3 4 12-28-2013 05:58 PM
DA* 55mm f1.4 with K5ii or K3 (AF speed) horc00 Pentax SLR Lens Discussion 9 12-18-2013 11:52 AM
All times are GMT -7. The time now is 10:30 PM. | See also: NikonForums.com, part of our network of photo forums!
