10-30-2015, 10:01 AM   #1
kentster's Avatar
Manual Focus with Sigma T/C
Any ideas why the focus confirm doesn't work with the T/C on?
Is there a setting that I need to enable to allow it to let me know when a shot is in focus when using manual focus ?
10-30-2015, 10:07 AM   #2
It could just not be working as reliably due to the loss of light.
If you want to use catch in focus, there's a menu setting that needs to be enabled.
10-30-2015, 11:35 AM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by kentster Quote
Focus confirm with your K-3 should work regardless of the lens/TC mounted or whether AF is turned on or off. Catch-in-focus, on the other hand, requires that the menu item (referenced in Adam's comment above) is set, AF switched on, and that the lens/TC have a conductive base. For some unexplained purpose, the camera does a check for electrical continuity between the data pin on the body and the lens mount face. If that check fails, catch-in-focus is disabled.
As Adam noted, there is the outside chance that the TC or aperture (manual aperture actuation) setting cuts the light to the AF system below the -3 EV(100) supported by your K-3. I would try again in bright light and with the lens wide open. Visually confirm that the lens is not stopped down as an additional check.
10-30-2015, 05:47 PM   #4
Canada_Rockies's Avatar
I have used CIF with the M 400/5.6. DOF is hair thin at 10 meters or less. It is very easy to overshoot before the camera has time to react. If doesn't work at all if I add the AFA 1.7x to the mix. (Wide open is f/9.5)
dslr, focus, focus with sigma, k-3, k3, pentax k-3
how to focus perfectly with manual focus lens? ghiaauto Pentax SLR Lens Discussion 17 09-30-2014 02:37 AM
For Sale - Sold: Sigma A 28-70/2.8 with caps & hood (manual focus) thornburg Sold Items 2 01-03-2014 07:55 AM
Can't change from Manual focus to Auto Focus kellyy17 Pentax K-r 11 03-06-2013 09:37 AM
K-5 with Sigma lens - Manual focus not working Jyved Troubleshooting and Beginner Help 3 01-10-2011 02:39 PM
First try with manual lens - C & C please junkdon Post Your Photos! 7 08-02-2008 11:18 PM
All times are GMT -7. The time now is 07:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
