11-15-2015, 01:59 PM   #1
K-3II can't select SD card slot to use
Apparently the K-3II has the same lame choices for use of the card slots.
You cannot change from one slot to the other anywhere in the menus. I have a Flucard, and prefer when I'm not using it to fill SD1, the non Flucard shot, first. But if I remove the SD1 to transfer files, and happen to fire up the camera with just a card in SD2, it will continue to write to SD2 until I take THAT card out and force it to write to SD1 again.
How do I complain to Ricoh to get them to just add the ability to choose which card to write to?
11-15-2015, 03:35 PM   #2
QuoteOriginally posted by Oakland Rob Quote
Yes, it works the same as on the K-3 and the 645Z. No, it is not super intuitive and no, it does not support a free selection of where/how to write. To complain to Ricoh, I used to suggest their online response form, but given the current state of their U.S. Web site I suspect that will be no help. You might want to hazard joining their online forum and posting a rant (suggestion) there. Ricoh does not monitor Pentax Forums, but they may do a better job on their own turf.
Home - RIAC Community
11-15-2015, 03:46 PM   #3
It is a very annoying feature too.
I wonder if there is some engineering logic to the restricted way Pentax have implemented this? I can't see any, but I presume it was a choice they explicitly made.
What they have done breaks card-to-card overflow too, so there is a lot to dislike about it.
11-15-2015, 06:44 PM   #4
Given the state of their current site I don't think they monitor that either
11-16-2015, 08:46 AM   #5
I wrote a snarky post about the lack of Ricoh presence there, and lo and behold someone replied. So I think someone is now monitoring it. I posted my card swap beef there; we'll see.
And to add to my complaint, for those using Flucards what is the best workaround to switch from writing sequential RAW to slot2 to JPEGs to only the Flucard, which must be in slot 1? It appears that pulling the card from slot 2 and switching to JPEG is the only way? could it be that lame?
11-16-2015, 10:43 AM   #6
UncleVanya's Avatar
There appears to be an option to change which card is written to in movie mode. That seems to indicate they thought about this need in that context at least.
In practice I think that pulling a card out as you indicated is the only way to switch this right now.
11-16-2015, 08:20 PM   #7
There's an even more annoying slot issue for me than clumsy slot selection... because yesterday I quickly grabbed my K-3 to fire off a nice burst of 20 plane shots, forgetting that earlier I'd been doing some housekeeping on my SD cards in the PC and they were still, er, in the PC!
20 shots, no SD cards, no photos! And the darned thing let me do it!!! So I checked my K-5 - it's the same. Can't quite see the point of being able to fire off shots when there's no card in the camera - or have I missed a setting, or something?
07-16-2016, 07:20 AM   #8
Weevil's Avatar
Well, this is a bit annoying to shut down + remove + turn on + reinsert etc etc... I know that trick since the K-3.
To me , the simplest and most intuitive way to implement that card slot switch in the software , would be to use the "Card slot switch button" (that allow to switch in playback mode) in combination with the front e-dial, but in normal shooting mode... should be pretty easy to code that in a future software. I don't know why they did not already did it in the K-3...
---------- Post added 2016-07-16 at 10:21 ----------
QuoteOriginally posted by Dave L Quote
Yes this is another thing easy to implement...
Canon has a warning...
I tend to always leave one SD in the camera to prevent that...
07-16-2016, 12:52 PM   #9
UncleVanya's Avatar
QuoteOriginally posted by Weevil Quote
That's odd. My K-3 yelps and complains if I have even one card missing (mine writes raw to one, jpg to the other.
camera, card, cards, dslr, fire, flucard, k-3, k-3ii, k3, pc, pentax k-3, sd, sd card slot, sd1, sd2, shots, slot, switch
K-S1 SD card slot failure Sandy Hancock Pentax K-S1 & K-S2 3 04-15-2015 02:47 AM
Which SD card to use for hi-speed burst shooting with K-30? GixxerMKD Pentax K-30 & K-50 11 02-24-2014 12:27 PM
K10 can't read SD card saladfunky Troubleshooting and Beginner Help 2 07-19-2011 01:54 PM
Pentax K-7 SD card slot problems ed coleman Pentax DSLR Discussion 7 11-15-2010 11:00 AM
Realignment of K10D SD card slot without sending it back to Pentax? Narcoleptic Pentax DSLR Discussion 4 09-15-2007 11:34 AM
All times are GMT -7. The time now is 04:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
