11-17-2015, 11:30 AM   #1
K-3 w/ Capture One Pro - Purple Edge
Does anyone here use C1 w/ a K-3?
My photos are showing a purple edge on the right (landscape), but the same raw files are not showing any problems when processed in Aperture or Photoshop.
Could C1 be catching a sensor issue with my camera?
PENTAX K-3  Photo
PENTAX K-3  Photo
11-17-2015, 11:59 AM   #2
It's the edge of the film, just slide it over in the negative carrier a little....
11-17-2015, 12:10 PM   #3
Every RAW image has a 'border' that is normally cropped out, depending on the aspect ratio the camera shoots in. Since the issue doesn't appear in Aperture or Photoshop, this looks like an issue about how your C1 crops off the RAW edges (or not) of PEFs or DNG's, rather than anything hardware.
11-17-2015, 12:35 PM   #4
QuoteOriginally posted by seanjmc Quote
Haha!
Thanks for the explanation.
I just checked and C1 only has this issue with .DNG files, not .PEF.
11-17-2015, 12:57 PM   #5
6BQ5's Avatar
I get the same line. C1 is very good at ignoring image resolution settings and it will display everything that is recorded in the RAW file. For example, when I shoot with my Q7 and an 03 fisheye I can see the black corners caused by the lens not being able to cover the entire 1/1.7" sensor. I consider this more of a blessing than a curse. Better to have too much information than too little.
Oh, and I also shoot in DNG.
11-18-2015, 08:28 PM   #6
ScooterMaxi Jim's Avatar
You know, I notice it every now and again, but not sure if it's always there. It reminds me of the shift you sometimes get when realigning for CA in other programs (typically Picture Windows Pro in my case).
I'd say, don't worry - be happy (once you crop out the edge). Those of us who have transitioned from Lightroom to C1 for most of our work are aware of the considerable advantages we're reaping.
11-19-2015, 01:37 AM - 1 Like   #7
QuoteOriginally posted by drolph Quote
So much for the "DNG" is universal talk. The quality of the various tool implementations varies and apparently C1 adds a decorative border for your entertainment pleasure.
11-20-2015, 10:21 AM   #8
In the release notes for the latest level (8.3.4) of Capture One, the Supported Cameras section for Pentax lists:
K-3 (PEF only)
This is something I've never understood, especially since the K-3 II and most other Pentax cameras are listed as supported without the qualification "(PEF only)".
Perhaps the purple edge is a symptom of whatever the problem is with K-3 DNGs in C1.
Anyone have any insights on this restriction?
11-20-2015, 03:10 PM   #9
Any way to go from DNG to PEF?
11-30-2015, 03:18 PM   #10
QuoteOriginally posted by Sherman Quote
K-3 (PEF only)
Not according to Phase One Knowledge Article 2063, indicating RAW file formats supported:
Pentax: K-01, MX-1, K-3II, K-3, K-5 IIs, K-5 II, K-5, K50, K-30, K-r, K20D, K10D, K7, KX, K200D, K110D, K100DSuper, K100D, K2000/K-m, *istDL2, *istDL, *istD, *istDS2, *istDS, Q10, Q7 (FW1.0.0 Only), Q (PEFOnly)
I haven't had any notable problems with DNG conversion on the K-3.
12-02-2015, 01:32 PM   #11
Capture One support for K-3 DNG
QuoteOriginally posted by ScooterMaxi Jim Quote
There is a conflict between the Capture One release notes and the Knowledge Base article 2063. The release notes for both Capture One 8.3.4 and the new 9.0 state that the file support for the K-3 is PEF only, but article 2063 does not list this restriction.
I sent a request for clarification to Capture One Support, and here is the verbatim reply:
Hi
We still restict compatiblity as fully with PEF file but the DNG should be DNG 1.4 compatible which is supported.
But DNG files are still just that DNG, and not a PEF which is camera specific.
PEF = K3 specific
DNG = a generic DNG file.
Kind Regards
Phase One Support
I'm not quite sure how to interpret this!
12-02-2015, 03:00 PM   #12
SNIP...I just checked and C1 only has this issue with .DNG files, not .PEF.
Way back when I tested Google Picasa, PEF files had a band of purple static at the edge while DNG files cropped it out. I've stuck with DNG through different cameras and software (Bibble, AfterShot, LR and Photoshop) and never noticed the problem again. But I don't use C1.
12-02-2015, 11:25 PM   #13
Hi
PEF = K3 specific
Kind Regards
Phase One Support
Well, I wouldn't try to understand what is, basically, nonsense. Quite a bit of back-and-forth has taken place with Pentaxians regarding particular models (DNG only especially) that were not originally supported. The DNG created by Pentax is not the least bit generic - and the two profiles supported for the K3 work in the same way whether the extension is PEF or DNG. As they say, a raw from the same camera is just that. A raw is a raw is a raw.
12-03-2015, 12:01 AM   #14
Possibly relevant is this thread from the other forum of several years ago:
Re: Correction to PEF, and comment on Magenta Edges technique...: Pentax SLR Talk Forum: Digital Photography Review
Read all the answers from GordonBGood. He was the Pentax wizard of the time and mentions the row of pixels that was used by Pentax (and other manufacturers) to store some raw data parameters. specifically black level offsets in Pentax's case. How this may have been related to the "magenta line" problem of the K20D (for which Gordon wrote a correcting program) is also mentioned. Not sure if this is at all related to the current magenta line in Capture One output but note the bit where DNG strips out this border row and (at one time?) was reporting a smaller file size than a PEF format file of the same image. I often wonder what happened to Gordon.
c1, dslr, edge, k-3, k-3 w/, k3, pentax k-3
Peak Design Capture Pro Dropped My K-3 Today Doundounba Pentax DSLR Discussion 29 06-07-2016 11:58 AM
Capture one 8 pro K-3 II support zvon Pentax K-3 5 09-05-2015 06:26 PM
anyone use capture one pro 8 by phase one software Murfy Digital Processing, Software, and Printing 31 04-28-2015 07:18 AM
Capture One 7.2.1 supports K-3 Viennese Pentax K-3 16 04-19-2014 10:10 AM
No plans from Capture One pro for K-3 file compatibility wizofoz Digital Processing, Software, and Printing 6 02-28-2014 06:26 PM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
