Originally posted by interested_observer Some thoughts.....
- For $750 to $900 you are in the upper price reaches of tripods. I would think that even with carbon you could find equivalent units for less. You need to look. My price range is substantially less. Are you going to backpack? How critical is weight?
- In terms of wind loading, you can hang your bag from the bottom of the center column (you will be shooting with out the center column extended for the best stability) in order to weight the tripod down for additional stability.
- You are going to need a head. If you are planning on using a ballhead, you will want one that can pan with a panning clamp that sits above the ball. Something along the lines of an Acratech GP or Arca Swiss P0
- A CPL will not uniformly apply its polarization on focal lengths wider than about the mid 20mm. Just the laws of physics and the way light can bend (or not).
- Back to the tripod - what do you like - twist legs or flip lock legs? Height of the tripod? Type of feet on the legs? For that amount of money, you really need to like the set of legs you are going to acquire. Also for that sum you could afford to take a look at Really Right Stuff (RRS) tripods.
- You might also consider supplementing the DA* 16-85 with the Sigma 8-16 for really wide shots and the DA 60-250 for telephoto. Also consider stitching pano shots with any lens (including ultra wide angle lenses). Also, consider the AW 1.4x teleconverter.
Thank you for you tips. Really helpful.
I will select one from 1544T or 2541. No other models. They are $800 in Australia and I think I can afford one. I am more happier with 2542T (tried it in store) however its price is horrible in Australia.
The only purpose I will be using a tripod is for landscape. But I don't like the exaggrated effect by super wide lens. The long focal length > 200 equivlent is also rarely used.
I would like to know if 1544T is stable enough for pixel shift. If it is YES I will go with 1544T otherwise 2541.
You said that "A CPL will not uniformly apply its polarization on focal lengths wider than about the mid 20mm". Is it 20mm equivlent or 20mm APS-C?
Many thanks again
Yubin
---------- Post added 11-19-15 at 03:27 PM ----------
Originally posted by interested_observer Terry - Have you considered wooden tripod? It's difficult to beat the natural features of wood for dampening vibration...
Also, you can usually find some large wooden surveyors tripods that are reasonable.
I am a surveyor
if I am going to use a total station I would select a wooden tripod.
If it is just an automatic level then a very light aluminum is enough.
