Originally posted by MRCDH Mcgregni, thank you for you comment; I will look into the AF-540. The battery was recently purchased and was fully charged before I went to the shoot. The 2-3 seconds I mentioned was only a guess (things always seem longer when you are waiting). Since I was shooting butterflies in this venue I wanted to capture the shot before additional movement or having the subject fly away. I got over 150 good captures in 2.5 hours so I really can't complain to much, which when you calculate it out is less than 2 minutes per shot, and this is about what you were estimating. Thanks again!!
Jtompen, mattb, howieb, thanks for your feedback; after reviewing the imputs I have received it appears the camera is recycling, relative to the pop-up flash, as it should, and the number of pictures I captured was not bad. I guess I was a bit impatient and it was not the recycle rate that was at issue. All in all the K-3 still is performing in an excellent manner.
