12-09-2015, 09:34 AM   #1
Requeste to Santa for K3 updates
Hi everyone!
The 645Z and 645D received a firmware update and since it's almost Christmas, I thought we could write a little "wish list" for Santa-san at the Pentax headquarters.
So here is my wish list :-)
  1. TETHERING!!!
    Come on! We are in 2015 and almost 2016!
    And please, don't release a costly software!
  2. RAW histogram (not jpeg)
    I would love that! It would be a great way to check te correct exposure and to squeeze the best out of the (already excellent) sensor.
  3. More reliable LV histogram
  4. SD card selection
    It's nice to provide two SD slots. It would be better to let us choose the card
  5. Zoom (100%) on focus point
    When I review a picture I just shot, I always "scroll" to the selected focus point. It would be great to have the option to zoom directly to that point
  6. In Live View mode, highlight alert is applied AFTER focus peaking, which is displayed in ... white. So with focus peaking enabled, you can't make the difference between in focus areas and overexposed areas.
  7. Better focus peaking? adjustable color? sensitivity?
    I find focus peaking really hard do use and not sensitive enough. I've used other cameras and it could be way better. For example, being able to choose a specific color, like the red highlight alert. I would then choose the B&W mode focus peaking in red, for example.
    I also think focus peaking is not sensitive enough. I think the "analysis" is made on the previewed image (on the screen) and not on the real image.
  8. Video sensor stabilisation
    It was the case on older models. So why use software stabilisation? Or both?
    [Edit:] Apparently, the sensor stabilisation is too noisy for that ;-)
  9. Focus peaking while recording a movie?
  10. Interval movie record (Timelapse): 1/30s limitation
    Why are we limited to 1/30s when we shoot at longer intervals? It's so sad :-(
  11. Get rid of the 3 consecutive images in Interval movie record mode (Timelapse)
    look a this video:
  12. Better video format codec (and pixel binning)
    Or is it limited by the hardware?
12-09-2015, 09:45 AM   #2
One of the reasons I did not upgrade to the K-3 is that AFAIK you lose the extended ISO 80 mode that the K-5 offers and can only shoot as low as 100. If this were an issue that could be corrected with a firmware update, it might be nice to have that back.
12-09-2015, 10:00 AM   #3
QuoteOriginally posted by pathdoc Quote
I did not know the K5 had that feature. But, since it's extended ISO and not base ISO, does it really matter?
Indeed, lower base ISO would be great, but I doubt this could be implanted in a firmware update...
12-09-2015, 10:02 AM   #4
bertwert's Avatar
QuoteOriginally posted by Azergoth Quote
RAW histogram
You can't do that, what are the histograms I'm looking at on my K-50 when I take RAW then?
TETHERING!!!
Yes! On the K-50 as well please!
12-09-2015, 10:03 AM   #5
Regardless of whether it's base or extended, I do seem to get better results at 80 and I hope Pentax goes even lower with the successors. Among other things, it helps control close-range overexposure when using my film-era ring flash on the 35 Macro.
12-09-2015, 10:05 AM   #6
QuoteOriginally posted by bertwert Quote
No, it's actually the histogram of the jpeg preview embedded in the RAW file ��
So if you have overexposed parts of the image, some of them can be recovered in post! �� (some...)
It should be on all cameras!
12-09-2015, 10:06 AM   #7
bertwert's Avatar
So if you blow some parts of the image, some of them might be recovered in post!
Ahh. Ok.
12-09-2015, 10:07 AM   #8
Maybe because you expose to the right? 😉
03-28-2016, 03:06 AM   #9
I've added:
and edited the sensor stabilisation in video mode: the sensor stabilisation would apparently be too noisy ;-)
I would also love three other things:
  • Reaching auto ISO when you try to go lower than 100 iso. The green button works, but why not on the selection wheel?
  • I would like to have the B pose beyond 30". I've special settings stored in a User mode and I can not quickly switch between shorter than 30" and longer than 30" exposures
  • More reliable LiveView histogram
What do you think?
dslr, focus, interval, k-3, k3, mode, movie, pentax k-3, record, santa for k3, sd, stabilisation, video
To K3 or not to K3... Jeff Pentax K-3 37 06-19-2015 09:10 AM
Was Santa Good To You? Kerrowdown General Photography 88 01-01-2015 06:55 PM
Suggestion Updates to O-GPS1 article for K-01 jbondo Site Suggestions and Help 2 12-10-2014 12:47 PM
Has firmware updates addressed this on K3? Spodeworld Pentax K-3 5 11-27-2014 12:14 AM
Santa left a K3 on my doorstep!! monochrome Pentax K-3 21 12-23-2013 09:37 AM
All times are GMT -7. The time now is 12:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
