12-14-2015, 06:30 AM   #1
Timelapse Exposure Issue
Hi everyone, I am making timelapse photos using the K3II interval timer. I am using a 5 second delay between shots and shooting raw. The camera is set up on Program and on a tripod. However it seems that every frame has a bit of a different exposue and as you move through the photos on a time line there is flicker present because of exposure differences. Any help. Thanks kenosha pentax
12-14-2015, 07:12 AM   #2
johnmflores's Avatar
I've had a similar issue with a K-3. Have you tried Manual mode to remove that variable from the problem?
12-14-2015, 07:29 AM   #3
I have not tried manual mode. Generally my timelapse exposures last from half a day to all day. kenoshapentax
12-14-2015, 08:02 AM - 2 Likes   #4
enoeske's Avatar
QuoteOriginally posted by kenoshapentax Quote
...The camera is set up on Program ...every frame has a bit of a different exposure
Unless the light stayed perfectly/exactly the same, any auto mode will give you different exposures. That's why you lock things down for time lapse. Manual mode. Turn off auto white balance. Turn off auto focus.
12-14-2015, 08:13 AM   #5
Tjompen1968's Avatar
Always everything in manual when doing a timelaps. If you then get flicker it can be the result of aperture.
12-14-2015, 09:16 AM   #6
There are some good tips here: reducing flicker for stop-motion animation and time-lapse photography | After Effects region of interest. Your best bet is reducing the flicker in the input through your setup (all-manual), but some time lapse software also has a deflicker function.
12-15-2015, 12:39 AM   #7
Thank you Tjompen1968 that was a great video. Discovered I will need to turn off my AWB and will be looking at if the Mirror in the K-3 to see if it is moving back and forth during my time-lapse.
dslr, exposure, k-3, k3, pentax k-3, photos, timelapse
K20 exposure issue Shoedog47 Maintenance and Repair Articles 3 11-04-2015 12:49 PM
Film exposure issue? theSixtyEight Film Processing, Scanning, and Darkroom 9 06-29-2015 12:48 AM
K-X exposure time issue steurm Troubleshooting and Beginner Help 4 04-24-2015 08:49 AM
Exposure issue with K-50 nugget247 Pentax K-30 & K-50 4 02-28-2015 05:47 PM
K-50 auto exposure issue ma.s Pentax K-30 & K-50 29 10-18-2014 08:38 PM
All times are GMT -7. The time now is 03:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
