12-20-2015, 04:29 PM   #1
Rayn's Avatar
K-3 II Battery grip showing no battery?
The battery grip buttons work fine, but shows no battery in the K-3 II's battery menu (the battery is crossed out). The batteries are charged and working. This started happening today after I accidentally took out the battery while the K-3 II was on... but I'm sure the camera has a failsafe for this. It shouldn't cause it to malfunction like this, should it?
I tired removing the batteries, but other than that I'm at a loss... The camera works fine with the internal battery, but not the grip anymore.
Any idea what could be the problem?
12-20-2015, 04:33 PM   #2
Perhaps you put in the battery backwards? The grip tray does physically allow for this, and it's gotten me a few times.
12-20-2015, 04:38 PM   #3
Rayn's Avatar
Nope. Checked.
12-20-2015, 05:16 PM   #4
honey bo bo's Avatar
It happened to me last spring when I charged batteries and put them in while the camera was turned on it would show in the menu that they were dead. I would turn the camera off & on they would show on after a short wait. These batteries were`` ACME Dynamite and Battery Co China Ltd ``( Wiley Coyote`s Supplier).
After 4 or 5 times doing this it just started to work over time I didnt do anything special and to this day they are working fine. I just wonder because they were Brand X that the camera had trouble recognizing them at first and then finally gave them a pass.
12-20-2015, 05:59 PM   #5
My k5 does this too. Recognizes Pentax battery not aftermarket. On the add on grip.
12-20-2015, 06:34 PM   #6
Rayn's Avatar
QuoteOriginally posted by honey bo bo Quote
Unfortunately, I have 3 original K-3 batteries and they worked fine, in both the grip and camera for months. It was only after today's little incident (not even sure that was the reason, but probably) that the K-3 II battery grip shows as no battery. I it's been on for hours now, but still not working. I'm affraid this is probably a different issue.
QuoteOriginally posted by condor27596 Quote
The batteries are all original Pentax, only the grip is 3rd party, but it was working fine for months.
I'm just hoping this is indeed a problem with the grip, and not the K-3 II, because other than the K-3 II not seeing the battery, the grip works fine. So the connection is working.
But seriously, if removing the battery can cause damage to the camera, that's a serious design flaw.
12-20-2015, 06:55 PM   #7
I don't have a K3 or a grip but just for the fun of it, try removing the grip, turn the camera on like you are going to use it, turn it off and replace the grip with the battery in the grip. The camera might start seeing it again.
12-20-2015, 07:42 PM   #8
QuoteOriginally posted by Rayn Quote
I've got the reverse. My grip is Pentax and the batteries are 3rd party. Something I forgot to mention earlier is clean the battery contacts there may be a film on them. I use an Ink pen eraser because they have a minute bit of grit on them.
12-21-2015, 03:34 AM   #9
Have you tried removing the battery from the camera and just having a battery in the grip? What happens then?
Have you gone into the menu and set battery priority?
Take the grip off. Operate the camera on internal battery and then reattach the grip and see what happens.
Regards
Chris
12-21-2015, 05:03 AM   #10
Rayn's Avatar
QuoteOriginally posted by seventhdr Quote
The K-3 II won't turn on.
Yes. That's where I noticed something's wrong, as the grip battery was crossed out.
12-21-2015, 09:22 AM   #11
Maybe the pins in the grip are bent. I do this sort of stuff often (removing the battery while camera is on) and nothing ever happened. Try using 6 AA batteries. They use different connector pins.
12-21-2015, 01:31 PM   #12
Rayn's Avatar
QuoteOriginally posted by zvon Quote
No bent pins. But I'm glad to hear that removing the battery usually isn't an issue.
Same. K-3 Won't turn on.
So either the grip battery connection died for no apparent reason, or (and this seems more likely) the camera connectors are fried.
I tried disassembling the grip to check the connections, and managed to remove all but a single damn screw, which simply would not loosen. So that's not happening...
12-21-2015, 03:06 PM   #13
Although I have done this often without incident, the K-3 manual does warn:
- Do not open the battery cover or remove the battery while the power is on.
Which suggests that the camera can't talk to the grip. There is circuitry in the grip, and with cheap third party grips you never know the quality of the electrical components, the soldering, the oxidation or corrosion of parts inside etc.
If you can, try a another grip (3rd party or Pentax). That should help you isolate the problem to either grip or body.
batteries, battery, dslr, grip, ii, ii battery grip, k-3, k-3 ii battery, k3, pentax k-3
K-3 incorrectly reports battery grip battery dead tram57 Pentax K-3 26 06-03-2016 01:38 PM
For Sale - Sold: Pentax BG-5 Battery Grip for K-3 and Pentax Battery tyrepeddler Sold Items 3 07-06-2015 11:04 AM
Battery grip battery not showing up Kees-Jan Troubleshooting and Beginner Help 12 05-23-2015 02:33 PM
Battery Grip on K-3 and K-5 II Problem morph00 Troubleshooting and Beginner Help 11 02-03-2015 01:55 AM
Will the k-3 take the AA battery adapter or do I need to purchase a battery grip Sorver Pentax K-3 8 12-12-2014 01:08 AM
All times are GMT -7. The time now is 03:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
