01-22-2016, 06:12 PM   #1
Clarkey's Avatar
K-3 ii Pixel shift for slide/negative copying?
Just wonder if anyone has tried it, and what their results were?
Also, I don't think it is possible, but any possibility of flash use with pixel shift?
01-22-2016, 06:32 PM   #2
QuoteOriginally posted by Clarkey Quote
I was trying to make pixel shift to work with flash but it is very hard and not practical. In essence, If you have a wireless trigger, you can try to take pixel shifted images with shutter times around 2-3 or how many seconds you want so you have time to manually trigger (test) the flashes 4 times. I tried it a couple of times just for fun of it and results were ok but you have to shoot in the dark or at least very dim room because of long exposures. Also, you have to find a rythm for triggering the flashes and take a stopwatch because you do not hear when the next picture is beeing taken. It would be cool so camera just triggers the flash four times, each time it takes a new image. I don't see the problem to it why that would not be possible.
01-22-2016, 06:46 PM   #3
I guess pixel shift could be worth it for better colour, but I can't try it since I only have a K-3. Resolution is already OK for slides, so I'm not sure I would be using pixel shift to realize better resolution.
I would use an incandescent lamp for better colour purity.
My settup uses a projector without its lens and the camera with a DAF100 Macro lens focused on the slide. It is very quick with remote control feeding.
John.
01-22-2016, 08:32 PM   #4
Using it for slides would be a perfect application, as long as your setup is sturdy and your light source is constant.
01-22-2016, 09:50 PM   #5
bobbotron's Avatar
I have a constant light source DIY slide copier. I would LOVE to have a k3II to try on it!
01-22-2016, 10:42 PM   #6
Digitalis's Avatar
Some flashes have a stroboscopic mode, Pentax flash units have a modelling light setting that can be used. Failing that the Godox AD180 and AD360 both have strobe modes that can be set to fire at 1hz~99hz depending on the power level needed.
01-23-2016, 12:04 AM   #7
rgk
I justified a recent K3ii + DFA 100 macro lens purchase for this exact purpose. Intending to use the pixel shift feature. Not yet underway.
BK
01-23-2016, 08:53 AM   #8
Clarkey's Avatar
QuoteOriginally posted by jhmos Quote
John.
Yes, hoping for the better colour/ colour depth and absence of read noise I get from my scanner. I'm also hoping to set up a rig for my medium format films.
Are you using your setup for negatives as well? I have used incandescent bulbs before, also thinking I might try a 5000k LED bank, since they are now so cheap.
I'm hoping.
Thanks for this, I'd forgotten about the "modelling" and strobe modes.
01-23-2016, 09:12 AM   #9
Oldbayrunner's Avatar
My 540fgz's use modeling and my Sigma 610 Super has modeling but also uses a Multi flash mode with selectable frequency and number of flashes.
01-23-2016, 09:16 AM   #10
Clarkey's Avatar
QuoteOriginally posted by zvon Quote
Good to know. I expected something like this - Pixel shift is very first generation, right now, and I don't expect full integration with the rest of the system.
dslr, ii pixel shift, k-3, k-3 ii pixel, k3, pentax k-3, pixel, shift, shift for slide/negative
Questions re: K-3 II pixel shift and Astrotracer gazelle01 Pentax K-3 102 03-06-2017 06:23 PM
K-3 ii Pixel shift of stars / night sky Conqueror Pentax DSLR Discussion 33 07-10-2015 03:16 PM
K-3 II Pixel shift for Macro? Omestes Pentax K-3 6 06-12-2015 08:13 PM
K-3 ii & Pixel Shift: How still is still? ahw Pentax K-3 19 06-08-2015 09:31 AM
K-3 II pixel shift resized. Wow factor. JimmyDranox Pentax K-3 21 04-25-2015 09:37 AM
All times are GMT -7. The time now is 06:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
