01-30-2016, 02:00 PM   #1
Setting up GPS
So I've moved on from Pixel Shift to GPS. The book says press the little button and a light comes on and an icon appears in the LCD screen, and they do. The light and icon are red, which apparently means 'No Positioning; I've calibrated the GPS by rotating as per instructions, and got the confirmation, but no GPS info in the info screen. What did i fail to do?
Thanks in advance.
Tuggie76
01-30-2016, 02:11 PM   #2
Just to be sure, were you outdoors and in an area with good sky visibility?
01-30-2016, 02:32 PM   #3
O/k, I'm sitting in my cozy basement, when I can pluck up courage to go outside I'll try again!
01-30-2016, 02:38 PM   #4
QuoteOriginally posted by tuggie76 Quote
Sounds good. The GPS probably won't work indoors unless you're near a window
01-30-2016, 02:45 PM   #5
I took the plunge (it's actually quite mild today) and it worked fine! A friend who has one said he had to do all kinds of stuff to get it to work, but that was easy!
What next to play with?
Thanks Adam.
Tuggie76
---------- Post added 01-30-16 at 05:42 PM ----------
One more thing, now I've woken it up, how to turn it off so as not to derplete the battery?
Thanks
Tuggie76
01-30-2016, 05:09 PM   #6
Press the GPS again I believe.
01-30-2016, 05:26 PM   #7
QuoteOriginally posted by Tony3d Quote
Yes the light goes out, but does that mean it' not working in the background, and should I change settings in the menu?
01-31-2016, 04:39 AM   #8
When the lights off the GPS UNIT IS OFF.
dslr, gps, icon, info, k-3, k3, light, pentax k-3, screen, thanks, tuggie76
Setting time, GPS and the K-3II Oakland Rob Pentax K-3 2 11-12-2015 02:28 PM
Setting up the Q7 for adapters Suleeto Pentax Q 15 09-21-2015 08:37 PM
Macro interrupted while setting up... ts357 Photographic Technique 10 04-02-2015 09:53 PM
Setting up K30 User modes - is this combination possible? carlb Pentax K-30 & K-50 2 11-08-2014 09:53 PM
Setting up my first darkroom Pinko Film Processing, Scanning, and Darkroom 8 03-30-2014 05:08 PM
All times are GMT -7. The time now is 06:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
