02-15-2016, 01:00 PM   #1
jpzk's Avatar
Just received the K3 and needing help with some items please !
Hi everyone.
Just received my K3 and proceeded to set it up.
I am now at the decision(s) based on:
Custom Menu 3 .....
Item 16, 17, 18, and 19.
Not quite sure what to use in there given that I will use the K3 especially for the following:
Birding, including lots of BIF.
Also, in the "Recommended Settings" suggested when the K3 became available, it is said that it is better to NOT use the AF.S in continuous mode (in my case it is on "High" on the K5) unless necessary because it is "difficult" to use that when taking only one shot at a time.
I often fire the shutter only once, likely to be followed with a burst .... so what's so difficult about that?
Is it because the shutter is more sensitive than that of the K5 ?
One last thing (I think): I presently have PDCU 4 and using it quite a bit.
Now, with the K3, I have to install DCU 5. Will it be OK to delete the DCU 4 once DCU 5 is installed ?
Thanks for any help here, folks!
JP
02-15-2016, 01:03 PM   #2
bertwert's Avatar
QuoteOriginally posted by jpzk Quote
Custom Menu 3 .....
I don't own a K-3, so what are those options?
BTW, your signature tag is impossible to read
02-15-2016, 01:09 PM   #3
jpzk's Avatar
QuoteOriginally posted by bertwert Quote
Yeah ... That is what happened when I tried to change it !! See here: posts no. 215 and 218 ... https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/67605-pentax-pro...ml#post3529651
I'll just go and delete everything from that signature.
Thanks for the hint. I hadn't seen that.
02-15-2016, 01:36 PM   #4
Luckily we have screenshots of everything
16 is just a little optimization setting, in case you want to set the first frame to have a different focusing priority than the rest. If you don't shoot moving objects much, the default is fine. 17 is focus or release priority. 18 controls how quickly the camera will re-acquire focus in AF-C mode if the subjects moves out of the frame (off= instantly, high=slowest, I believe). 19 is pretty simple, it just controls whether or not the AF will operate prior to shutter release with the IR remote control.
Hope this helps!
02-15-2016, 01:47 PM   #5
jpzk's Avatar
Hope this helps!
Yep that helped. And thanks for reply !
But I did set the priority for AF.C to "focus priority"
Any suggestion(s) about the other two items?
JP
Forgot this: BIF (Birds in flight) - or any other fast moving subjects - .... better to use which AF area? 9 points ? 27 points, spot?
02-15-2016, 01:54 PM   #6
csa
csa's Avatar
I'd also suggest getting the E-Book for your K3. I'm not affiliated whatsoever, just a happy purchaser. It goes beyond the manual that comes with the K3.
https://www.pentaxforums.com/forums/24-photographic-equipment-sale/295303-sal...tax-dslrs.html
02-15-2016, 02:24 PM   #7
jpzk's Avatar
QuoteOriginally posted by csa Quote
Thanks !!
I had forgotten about this ... very timely!
02-15-2016, 03:06 PM   #8
Des
I've tended to use spot in the past coupled with spot AE metering, but against the sky multiple AF points ought to be better. But I'm no expert. Listen to these guys:
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/282974-s...ing-birds.html
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/293580-bif-...-50-500-a.html
02-15-2016, 03:19 PM   #9
jpzk's Avatar
QuoteOriginally posted by Des Quote
Thanks for the lead.
Interesting read.
I am more concerned with the usage of the K3 based on specific parameters.
For instance, do people use the 27 points while following a BIF ? Is 9 points better? Why use a spot AF and under which circumstances? .... etc.
JP
02-15-2016, 10:25 PM   #10
Use AFA, it does all for you: initially bring the lens in focus with selected point as if it is AFS (focus priority, does not take shots unless the subject is in focus), then the AF switches to AFC and tracks the subject. It's the best.
AFC only is not good at getting in focus for the first frame.
02-16-2016, 07:08 AM   #11
jpzk's Avatar
Thanks for the reply !
I never thought of that because it is new to me.
Are there any other parameters which could also be useful in my set up?
.... such as Custom menu items 16 to 19, etc...AF area: spot, 9 or 27 points ?
Mind you, there aren't many BIF occasions these days because of the cold season as most birds are gone .... I can always try tofind some crows and gulls and practice with them !
Cheers!
dslr, help, k-3, k3, k5, pentax k-3, shutter
Urgently need help with firmware update K3 please ! jpzk Troubleshooting and Beginner Help 9 08-12-2015 08:58 PM
Problem with K3-Help Needed Please Setter Dog Pentax K-3 7 02-27-2015 03:47 AM
Just received some older equipment. Stevetopia Pentax Film SLR Discussion 6 12-26-2014 02:46 PM
Help me understand some settings on K3 Please Tom777 Troubleshooting and Beginner Help 2 05-24-2014 05:39 AM
Just received my first KX and have some concern on accessories it came with CarlitosReef Pentax Camera and Field Accessories 25 11-25-2011 09:42 AM
All times are GMT -7. The time now is 12:54 AM. | See also: NikonForums.com, part of our network of photo forums!
