Originally posted by zvon maybe they have been hard at work on k-1? but i would like some sort of an update for k3-2 there are some annoying things that could be changed. for example card slot select. if you have two cards inserted in camera, and camera is set to write only to slot 1, and then you take out the card from slot 1 (to copy the images to computer for example) and in the meantime you power up the camera, naturally camera switches to slot 2 as main card. but then, when you put the card back to 1 you can not select it to write to slot 1, there is no option to select the slot. so you have to take out the card from slot 2, power up the camera so that the slot can change back to 1, turn off the camera and put the card back in slot 2. pretty annoying. I do not know if i'm stupid and nobody else finds this annoying. Is that the case on k3 also?
I have the same thing on my K-3 but I have a slight workaround of leaving the write protect slider on my second SD card locked so the camera only writes to SD 1. If SD 1 is full, the camera won't take pictures and it only takes a second to pop out SD 2 and slide the tab to the unlocked position so I can write to card 2. I only have to futz with popping the card out if my first card fills up rather than every time I take one of the cards out. This also helps keep pictures from being randomly split between both cards since I only have to plug one into my computer to download all the pictures.
Another advantage is this forces me to consciously acknowledge that half of my space is gone, so I realize if I need to slow down on how many pictures I'm taking, such as on vacation where I don't have access to a computer to dump my cards. (Not that I've ever run out of space since I upgraded to two 64GB cards.)
