Originally posted by Crumplebury Hi All
I have a problem with my Pentax K3 but I'm not sure if it is a fault or something that I am doing wrong ? I use my K3 in manual for the most part and the problem seems to be intermittent. I set my iso then my F stop but sometimes I can't set my shutter speed above 1/90th of a second it will let me go below to whatever shutter speed i want but it will not go any higher than 1/90th of a second ? Looking at my camera this morning it is fine again but does not have a shutter speed now of 1/90th it will go above and below but not on 1/90th so i get 1/80th and 1/100th and above or below these settings ? I have tried different lens and i have tried taking out the battery for a min or two to reset the camera but still no different ? I have used my K3 in live mode and also for video recently and i am wondering if that is having anything to do with it ? I have not spoken to Pentax yet but I was just wondering if anyone here has had this problem and if so what maybe causing it ? Many thanks
Greetings.
You'll get shutter speeds of 1/80 and 1/100 if you have your EV stops (custom mode option 1) set at one-third stops; that's where I have mine normally. Setting it to half-stop will allow you to select 1/90.
In M mode, my K-3II will let me set any shutter speed/aperture/ISO combination so I'm not sure what's going on there. Do you mean that sometimes you can't select speeds faster (i.e. shorter) than 1/90? If it's locking you to a fixed shutter speed, maybe you've got it set to X?
