Originally posted by UncleVanya There are people who have both who posted that they like the 20mp output better than the 24mp - lower noise was the primary reason. The same sensor coupled with 14 bit RAW would be a real killer!
---------- Post added 03-10-16 at 11:19 AM ----------
The real gap in Pentax is the lack of a small external flash with wireless controller and master modes. That really would remove most objections around the loss of a pentaprism flash.
Excellent point. With two higher end cameras sans flash that is the minimum spec needed.
Even then, the K-3 also has ratio capability down to practically nothing which makes it even more versatile if you want just a very minor amount of fill with very little parallax, and the ability to use simple, reliable optical slave on a remote flash. While this might hardly ever come into play, it can be a real lifesaver when the need arises - sometimes unexpectedly. It's there, no need to grab it from the bag.
