03-09-2016, 01:35 PM   #1
Senior Moderator
Nass's Avatar
Is this sort of mult-shot possible on K-3II?
This is something I'd like to be able to do but I don't think it's possible on a K-3ii. I'm posting here in case someone knows a workaround or bodge that can do this.
I'd like to take 5 shots at the same EV, but which vary two of ISO, shutter speed and aperture that I choose. For example if my perfect exposure is f/5.6, 1/500, ISO 800 then if I choose to do this with aperture and shutter speed, I'd like to press the shutter once but for the camera to then produce 5 shots at same EV: 1/500 5.6, 1/250 8, 1/125 11, 1/1000 4 and 1/2000 2.8.
Anyone know a workaround for what I'm after?
03-09-2016, 01:55 PM   #2
Quartermaster James's Avatar
Interesting concept. I eagerly await an informed answer.
Not having heard of this as an option before, I am wondering if you know of a camera that does do this?
03-09-2016, 02:00 PM   #3
QuoteOriginally posted by Nass Quote
Yes, you can use five cameras in P mode, on a bench and fire them together with IR remote.
03-09-2016, 02:00 PM   #4
microlight's Avatar
Hi Nass. No, I don't believe so. There's a drive mode option that will shoot up to five exposures at variable EV values, but I can't see any method of doing what you indicate. Unless anyone knows different?
03-09-2016, 02:03 PM   #5
Senior Moderator
Nass's Avatar
Nope, never heard of it anywhere, just something I dreamed up as 'desirable'.
We all know about bracketing, which is like this but changes the EV. But I think in today's cameras there's so much latitude in RAW that conventional bracketing is maybe not as important as it once was. But, I operate a lot at wide open aperture and the depth of field is sometimes insufficient so I'd like a series of shots at same EV but different apertures so that one of the series always has the right depth of field. Lazy automationI know, but heck, isn't that why we have processors.
03-09-2016, 02:04 PM   #6
Pentax added advanced bracketing on the K-5, Ricoh removed it on the K-3
03-09-2016, 02:05 PM   #7
Sort of like focus stacking. No automatic way that I know of.
03-09-2016, 02:08 PM   #8
Hasn't this question come up in the past?
I don't believe there is a way to automate this or similar sequence (arbitrary EV defined for a series of one-stop increment shutter speeds) using the in-camera features. That being said, it may be possible to do so with a remote tether and a little custom coding.
03-09-2016, 02:11 PM   #9
Senior Moderator
Nass's Avatar
Yeah I did raise it as desirable before, as I couldn't figure out a how. But I wanted to doublecheck - maybe someone knew of a way I hadn't spotted
03-09-2016, 03:18 PM   #10
Na Horuk's Avatar
Would aperture bracketing do this for you?
I think some advanced triggers can do similar stuff, possibly through wifi
03-09-2016, 06:05 PM   #11
jimr-pdx's Avatar
The new Panasonics use 4k to grab a sequence of images with different focus depth so you can pick one or more as stills.
Those are 8Mpx limited and do not adjust the aperture though; it's cool but not as neat as your dream effect
03-09-2016, 11:14 PM   #12
The (P)Z-1 would do that manually. You could manually set a shutter speed / lens opening and then hit the exposure lock button. You could then turn either wheel and the EV would stay the same while you spun the shutter or AV dial.
03-10-2016, 12:36 AM   #13
Senior Moderator
Nass's Avatar
Yes, this is how I currently bodge it, aperture bracketing. This at least lets me get 5 shots with a range of f/stops. Of course as it's classical bracketing that also changes the EV value between shots, but I use RAW so they have the latitude to make the exposures ok.
aperture, dslr, ev, iso, k-3, k3, pentax k-3, shots, shutter, sort of mult-shot, workaround
Pentax K-3II is back on Amazon for $928.95 farhaddad Pentax Price Watch 7 07-17-2015 06:04 PM
Is This Even Possible? LOL magkelly Pentax K-30 & K-50 17 10-22-2014 10:40 AM
K-r AF dead (sort of), need service manual of some sort.. minahasa Pentax K-r 2 09-19-2013 11:55 AM
Sort of a possible issue urssu Pentax K-5 3 01-17-2013 11:48 AM
Is it not possible to make a range of dSLR's more like this? NorthPentax Pentax News and Rumors 8 05-23-2009 09:49 AM
All times are GMT -7. The time now is 06:43 AM. | See also: NikonForums.com, part of our network of photo forums!
