04-01-2016, 02:50 PM   #1
Just got my new K3II.....anything I need to immediately check ?
I just got my K3II and 18-135 WR lens kit.......Anything I need to immediately check functional wise ?
This camera was a Re-Payment for a loan to a friend and I want to make sure it doesn't have any known glitches ?
If I remember correctly there was an issue with getting the GPS to work on some early models ?
Software/firmware is 1.0 that is currently installed........Thanks for any input as just want to make sure there are no glitches before I put my lightly used K3 on the forum for sale.
04-01-2016, 02:56 PM - 1 Like   #2
Check that the camera powers on and off correctly, and that you can access the GPS menu.
See:
Pentax K-3 II Service Advisory - Pentax Announcements | PentaxForums.com
04-01-2016, 03:09 PM   #3
See:
Thanks Adam ! My serial number is 627xxxx so I'm out of the recall . I did check the power button and shutter release with PGS enabled and power button works fine.
04-01-2016, 04:39 PM - 1 Like   #4
Quartermaster James's Avatar
My advice is to put it through its paces and check all functions. I advise this from personal experience. My K3 had a flash synch issue. It may have been there from day one, it may have developed over time. I don't know. I hadn't used flash and the problem wasn't discovered until nearly two years into owning the camera. Luckily I had warranty coverage.
04-01-2016, 04:43 PM - 1 Like   #5
Put the battery on the charger and leave it there until fully charged. While that is happening, read the manual. There is a lot of good stuff in there. Once the manual has been read, you are in a position to try out the features that interest you. If something is not right, you will be prepared to detect the misbehavior.
04-01-2016, 05:38 PM   #6
I'm familiar with all the features on the K3......this is just a step up.....a kinda BIG step for me !
Wanna make sure just in case I miss something......Thanks.
---------- Post added 04-02-16 at 08:43 AM ----------
QuoteOriginally posted by Quartermaster James Quote
Quartermaster James......thanks. I'm one of the "Wierdos" that likes my camera without the flash.....lol.
Between my two K3's in 37K clicks........I never used it a single time.
04-01-2016, 07:32 PM   #7
mikeSF's Avatar
...and then get out there and take some pics!
have fun & congrats!
04-01-2016, 07:44 PM   #8
Heard & understood. Just illustrating a point. That the repair required so much replacement that the camera build date changed indicates, to my mind at least, a significant problem. The flash synch issue could well have been a canary-in-the-mine-shaft event. And a lucky one for me: if the shutter block had failed a couple of months later I would have been SOL. Just saying make sure all the things do what they're supposed to do. If you've got access to a Pentax flash, it wouldn't hurt to make sure it works right, HSS and all.
QuoteOriginally posted by Dlanor Sekao Quote
04-02-2016, 05:12 AM   #9
Yuuup ! Found a problem ! The body is fine.....BUT.....The 18-135 Just isn't sharp at all. Will give it a shot at in camera calibration and if that doesn't work.....it will go back !
04-02-2016, 07:07 AM   #10
a5m
Seems to be a hit or miss with the 18-135 in terms of sharpness. AF fine adjustment might help though.
Or just exchange it for the 16-85
camera, check, dslr, flash, glitches, k-3, k3, pentax k-3, step, time
I just got my GR! My impressions. drypenn Ricoh GR 4 06-02-2015 04:58 PM
K5 II - Check FA77 - Check FA31 - Check: Now should I keep my 16-50 2.8 Borislav Pentax SLR Lens Discussion 8 08-06-2013 08:14 AM
Just got my new K-30. What should I check to make sure is not DOA? jrcastillo Pentax K-30 & K-50 3 07-18-2013 08:05 PM
Just got my k5 and I need help Mtnberner Pentax K-5 16 10-24-2012 03:48 PM
So I need some help...I just got a sunpak 383 for my K10D. triplej96 Photographic Technique 6 05-06-2008 04:39 PM
All times are GMT -7. The time now is 06:28 AM. | See also: NikonForums.com, part of our network of photo forums!
