05-31-2016, 11:12 AM   #1
Genki's Avatar
Which Microphone Model and Brand do you Recommend to use with Pentax K3 and K1?
My suggestion is: Audio-Technica AT9940
  • Product Features
    • Element: Stereo Electret Condenser | Polar Pattern: Unidirectional | Frequency Response: 40-19,000 Hz
    • Sensitivity: -36dB (15.8 mV) re 1V at 1 Pa | Impedance: 2,200ohms | Power Supply: Battery/Plug in Power
    • Dimensions: 45mm(H) x 54mm(W) x 159mm(L) | Weight: 140g | Cable: 0.3m
    • Connector: 3.5 mm L-type gold-plated stereo mini jack
05-31-2016, 11:30 AM   #2
gorme's Avatar
The main question is what do you want to film with it ? Concerts ? Interviews ?
My use is mainly interviews and I have a Rode Videomic which is quite good. My best advice however would be to buy a mini-jack extender so that you can put the microphone closer to the person you film. It costs nothing and improve greatly the quality.
05-31-2016, 12:01 PM   #3
QuoteOriginally posted by gorme Quote
I also use the video mic pro (this one: Rode VideoMic Pro Compact Directional On-Camera VIDEOMIC PRO B&H).
It has on-board settings to amplify sounds or dampen background noise, and this is very useful if you're doing interviews in a loud place (think Photokina).
05-31-2016, 12:20 PM   #4
Genki's Avatar
VideoMic Pro Specifications
Acoustic PrincipleLine Gradient Active ElectronicsJFET impedance converter Capsule0.50" Address TypeEnd Frequency Range40Hz - 20kHz(selected HPF @80) Output Impedance200Ω Maximum SPL134dB SPL (@ 1kHz, 1% THD into 1KΩ load) Maximum Output Level6.9mV Sensitivity-32.0dB re 1 Volt/Pascal (20.00mV @ 94 dB SPL) +/- 2 dB @ 1kHz Equivalent Noise Level (A-weighted)14dB-A Weight 85gm Dimensions100mmH x 75mmW x 170mmD
05-31-2016, 12:22 PM   #5
I use the Rode Video Mic as well. For the price it works very nicely, although a lot depends on what you are willing to spend and what you are planning to record.
05-31-2016, 12:46 PM   #6
Genki's Avatar
Stereo VideoMic Pro Specifications
Acoustic PrinciplePressure Gradient Active ElectronicsJFET impedance converter Capsule0.50" Polar Pattern Address TypeEnd Frequency Range40Hz - 20kHz Output Impedance200Ω Maximum SPL134dB SPL (@ 1kHz, 1% THD into 1KΩ load) Sensitivity-38.0dB re 1 Volt/Pascal (12.60mV @ 94 dB SPL) +/- 2 dB @ 1kHz Equivalent Noise Level (A-weighted)20dB-A Power Options Weight 115.00gm Dimensions130.00mmH x 66.00mmW x 108.00mmD Output
05-31-2016, 02:11 PM   #7
hcc
hcc's Avatar
I have used the Rode VideoMic Pro shotgun on my K-3 and reviews are at: Rode VideoMic Pro shotgun reviews - Pentax Camera Accessory Review Database. My experience was positive and you may wish to read the review comments (2 reviews). I also share some experience at:
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/275789-experience-rode-videomic-pro-shotgun.html
Attention
After some careful signal processing and analyses, I suspect that the microphone mounted on the camera hotshoe does pickup some low frequency noise likely connected to the shake reduction (SR). See:
https://www.pentaxforums.com/forums/172-pentax-k-3/279013-sr-characteristic-s...uency-ies.html
If you want a clean signal, you may consider to avoid mounting the microphone on the camera hotshoe. This is valid for any microphone on most Pentax SLRs or SLRS with SR.
I hope that the comment may help.
06-01-2016, 04:42 PM   #8
I have a Azden SMX-10. Works fine on K-3/K-5/K-1.
But also a Zoom H1, and a small lapel microphone too. Each has it's uses.
brand, dslr, k-3, k3, microphone, microphone k3 k1, microphone model, model, model and brand, pentax, pentax k-3, pentax k3, power, stereo
Which Filter are better, to use or not use with Pentax K3, Pentax K3II and Pentax K1? Genki Pentax Camera and Field Accessories 40 06-17-2016 05:56 PM
Which camera/brand did you use before switching to Pentax and why? axelm7 Pentax DSLR Discussion 109 11-25-2014 10:18 PM
Which SLRs do you recommend to friends and family? shaX 07 Non-Pentax Cameras: Canon, Nikon, etc. 27 11-30-2013 08:39 PM
Which software do you use to import and process RAW files ? madbrain Pentax DSLR Discussion 67 08-02-2012 09:08 PM
Which combination of tripod and head do you use with your MF camera? alexfoto Pentax Medium Format 39 06-19-2012 09:24 AM
All times are GMT -7. The time now is 02:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
