06-02-2016, 08:27 AM   #1
Battery Life
I seem to be changing out batteries on my K3 MUCH more often than my K5IIS & K5. I know some of the issue seems to be with the grip my question is is this a glitch and are K3II owners experiencing the same thing. Also K1 shooters feel free to ring in. Just sayin' can we get a reliable firmware fix and can we PLEASE get a firmware update for the K3II focusing improvements on our K3's ???
06-02-2016, 08:48 AM   #2
jatrax's Avatar
Rated battery capacity is 740 on k-5IIs and 560 on the K-3. If that is "MUCH more often" to you then yes, performing as designed. The K-1 is listed at 760 shots but it is not clear if that is measured using the 50% flash standard or not. I seem to get less on the k-1 than on the k-3II but that's just subjective.
To be honest there are a lot of factors that will affect battery life, so many that it is really difficult to make comparisons even between the same camera with two different users and camera setups. Your use pattern will be very different than mine and battery life on the same camera might vary 50% just because of this.
I am always confused when I see people complaining about battery life though. For my use I swap out the battery when I come back from a shoot and charge the old one. I always carry a spare, but it is a rare day I ever use it. I've gotten 700 images on a battery many times with no issues. But battery life is really the last thing I have any concern over.
Curious what your use pattern is that makes this an issue? Lot's of bursts? Astrophotography?
06-02-2016, 09:07 AM   #3
Do you use live view a lot or keep the status screen on? Both of those will decrease your battery life, especially the former. That said, I can't say that I have any complaints about the overall battery life of either the K-1 or K-3.
Are you using an off-brand battery in the grip perhaps? Also, I'd recommend setting the camera to use the grip battery first, if you haven't already.
06-02-2016, 09:21 AM   #4
Why is that? I have mine set to Auto. It seems like it switches back and forth from one battery to the other until they're both depleted. Does having it use grip first make the batteries last longer, or just easier to change the dead one in the grip than in the body?
06-02-2016, 09:38 AM - 1 Like   #5
QuoteOriginally posted by r0ckstarr Quote
Both, I'd say. If the battery in the body gets low, the camera may die well before both batteries are depleted because it relies on the in-body battery when it first starts up. I've always experienced the best stability when the grip battery was selected to be drained first.
06-02-2016, 09:49 AM   #6
Quartermaster James's Avatar
Are you using an aftermarket fast charger on a regular basis?
06-02-2016, 09:57 AM   #7
That makes sense. I never thought of it that way. Thanks! I'm going to try it out.
06-02-2016, 11:36 AM   #8
And when the grips on it's easier to change the battery in the grip than the body. In fact, I've seen some posts suggesting the tog only uses the battery in the grip; no battery in the body. Not sure if that'll work though?
06-02-2016, 11:42 AM   #9
pete-tarmigan's Avatar
QuoteOriginally posted by JohnX Quote
I tried it once briefly. It worked.
dslr, firmware, k-3, k3, k3ii, pentax k-3
Battery Life RockvilleBob Pentax Camera and Field Accessories 10 12-15-2015 08:46 AM
PZ-1p battery life yusuf Pentax Film SLR Discussion 7 11-26-2014 02:20 PM
Q7- maximizing battery life ChatMechant Pentax Q 19 10-13-2014 07:58 AM
Battery Life Issue k-50 materialguy Troubleshooting and Beginner Help 5 09-04-2014 08:36 PM
Battery Life Number of Shots CWRailman Pentax Q 13 07-31-2014 10:45 PM
All times are GMT -7. The time now is 07:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
