06-11-2016, 02:20 PM   #1
meter looks different, can't figure out how to change it back
So in the year and half I have had the k3, I have never run into this. Apparently my meter changed from a scale with lines to +/- numbers. It will say +3.3 if I am over exposed, but no scale meter. I read the manual and I don't see anything about so I probably just missed it. I feel dumb. If I push the iso button, then I get the view in the viewfinder I am used to, but as soon as I half press the shutter (or also push back button AF), it goes back to the +/- numbers and the bar disappears. I have turned it off and on and removed the battery. Is this something very simple?
06-11-2016, 02:24 PM   #2
Did you enable the electronic level in the viewfinder? That takes the place of the EV scale.
The corresponding setting is found in the third tab of the record menu.
06-11-2016, 02:30 PM   #3
YES! Thank you, it's very hot here and I was outside getting frustrated and angry trying to fix it. I don't think I have used the level other than in live view. I thought it was exposure readings. DUH. I blame it on the heat.
button, dslr, half, k-3, k3, meter, pentax k-3, scale
Question count figure out why a listing can't be bumped up pearsaab Site Suggestions and Help 6 03-29-2016 07:46 AM
Hmmm.... can you figure it out? Dewman General Talk 3 12-05-2014 06:30 AM
Can't figure this out...? rollin Pentax K-5 6 04-25-2012 12:08 PM
Can't Figure Out Bellows Dubesor Pentax SLR Lens Discussion 12 03-14-2011 11:27 AM
Can't figure how to use old lens Brydean Pentax DSLR Discussion 3 12-28-2008 11:28 PM
All times are GMT -7. The time now is 02:55 AM. | See also: NikonForums.com, part of our network of photo forums!
