06-15-2016, 10:16 PM   #1
Leoi's Avatar
K-3 II burst speed faster in live view with K lens
Hello everyone
I've just received a Pentax K-3 II, and using it with the K 50 1.4 I realized the burst speed is faster using live view (about 8fps) than with the viewfinder. Is this normal? Is there any way I can get the same burst speed using the viewfinder?
06-15-2016, 10:34 PM   #2
The framerate should be the same in manual focus. The shutter sound will be different (louder) when shooting through the viewfinder, since the mirror also goes up and down.
Note that their are other factors that may affect your effective framerate, most notably whether or not distortion correction is on in JPEG mode.
06-16-2016, 12:43 AM   #3
Most camera's will go into a Mirror-lockup mode when using the Live view where the mirror flips up and remains up, as the mirror is not needed for live view as it is for the viewfinder. That's why it can achieve slightly higher speeds with live view. As an example the Canon 1dx mkii advertises 14 frames, and 16 frames with mirror lockup.
Hope that cleared up your question!
06-16-2016, 10:07 AM   #4
Leoi's Avatar
No, it's definetively slower.
Experimenting a little, I discovered the framerate slows the exact moment the metal frame of the back of the lens touches the pins of the mount. So then I put adhesive tape on the pins, put on the lens, and it shoots at 8.3 fps, but the diaphragm does not move!
06-16-2016, 02:16 PM   #5
QuoteOriginally posted by Leoi Quote
It's strange that this would happen with a genuine K-mount lens! I've heard of it with third-party and adapter M42's...
06-16-2016, 08:15 PM   #6
Leoi's Avatar
Well, I guess I'm more calm as I can't do much about it, I guess.
Discovering the problem cost me about 400 shots, though.
burst, burst rate, burst speed, dslr, ii, k 50 1.4, k-3, k3, pentax k-3, pentax k-3 ii, view, viewfinder
K-3 II + Manual Lens + Live View + Green Button = ??? Quicksand Pentax K-3 43 08-24-2016 02:01 AM
K-5 II live view noise and loose (?) sensor? sfkazimierczak Troubleshooting and Beginner Help 8 03-25-2016 07:58 AM
K-3 vs K-01 Live View Focus Speed - K-01 Wins! rmtschanz Pentax K-3 25 12-07-2015 06:02 PM
K-5 Live View AF Speed very good only with SMA DA 18-135mm Lens ? brosen Pentax K-5 3 10-23-2011 12:47 AM
K-R trouble focusing in low light with Live View using Pentax 18-55 kit lens sportv Pentax K-r 8 01-02-2011 06:42 PM
All times are GMT -7. The time now is 12:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
