06-17-2016, 08:47 PM - 3 Likes   #1
Converted Lightroom K-3 II Profiles
Here are the K-3 II profiles that have made it into lightroom which I have adapted for use with the K-3. This gives you the Bright, Landscape, Portrait, Vibrant, and Natural profiles. In develop if you go to the color calibration area at the bottom of the panel you will find them. You have to install these in your local user folder for them to appear. On windows it is in the appdata/roaming/adobe/camera raw/camera profiles/ directory. I'm sure it is similar on the Mac side. Since the sensor and imaging pipeline are nearly identical I would imagine that these profiles are accurate on the K-3. Close enough at any rate. These should give you the same color shifts that the various jpeg profiles give you. I have tested these and they all open fine. I have not compared with actual jpegs yet to verify their accuracy but they look fairly accurate from a couple of files I played with.
06-18-2016, 02:55 AM   #2
Crooski's Avatar
Thanks for the profiles Zosxavius
works perfectly in adobe photoshop elements.
Greetings Crooski
06-18-2016, 05:24 AM   #3
Sounds intriguing, unfortunately being a total ludite I've no idea what to do after downloading zip files. I tried copying the address you gave, but they don't show up on my camera calibration tab.
Thanks.
Tuggie76
06-18-2016, 09:50 AM   #4
screwdriver222's Avatar
Thanks. I have installed them ok. I will try them out later.
You have to install them in your local folder ie C/USERS/local folder, whatever your local folder is called.
Jeff
06-18-2016, 10:37 AM   #5
Tjompen1968's Avatar
On Win 7,8 and 10 put the files in the following folder. It will be hidden as default.
C:\Users\??????\AppData\Roaming\Adobe\CameraRaw\CameraProfiles where ????? is your username on the computer
06-18-2016, 01:49 PM   #6
QuoteOriginally posted by Tjompen1968 Quote
I copied and pasted this, changed the question marks to "USER", still no joy in either LR5 or CS6.
Tuggie76
06-18-2016, 01:58 PM   #7
QuoteOriginally posted by tuggie76 Quote
Tuggie76
What version of windows are you using? What is the name of the account you are logged in to? The User account name...
This is how my search path looks like C:\Users\Thomas H\AppData\Roaming\Adobe\CameraRaw\CameraProfiles
06-18-2016, 02:09 PM   #8
Hi, I'm using windows 7, this is as far as I get.
C:\Users\??????\AppData\Roaming\Adobe\CameraRaw\CameraProfiles I copied this and put it in the address box, changing the ????? to USER.
Tuggie76
06-18-2016, 03:49 PM   #9
Do you have a screen shot of the folder C:\USERS?
When you press the Windows key, you get a menu. On top of that menu, does it say: USER? Or does it say your name? And below you have Documents, Pictures etc?
06-18-2016, 04:08 PM   #10
Thanks TJ, How's that?
Tuggie76
06-18-2016, 04:55 PM   #11
Well, it looks correct... And the raw file you wish to open is taken with a Pentax K-3, not K-3 II?
06-25-2016, 06:09 AM   #12
Fabulous! Downloaded and installed onto LR 4.4, no problems.
This will save a heap of time having a starting point for RAW post processing closer to one of the Pentax JPEG defaults. Can take a long time sometimes just trying to get close to the Pentax JPEG look even before moving onto shadow corrections, local adjustments etc.
Thank you zosxavius. And behind the scenes presumably also Ricoh for working with Adobe to get the the K-3ii and K-1 JPEG defaults into ACR and LR. We're slowly being brought in from the cold!
06-26-2016, 12:04 AM   #13
robjmitchell's Avatar
Works a treat! thanks.
06-26-2016, 02:51 AM   #14
rayallen's Avatar
Location: Forresters Beach, Central Coast, NSW, Australia
Thank you very much. Installed with no problems.
06-26-2016, 05:02 AM   #15
Yes it's a k3ii. I see! they are for K3 not K3ii. Now I understand! Will I need a newer version of Lightroom to get them?
Thanks again.
Tuggie76
acr, camera raw, color, dslr, ii, k-3, k3, lightroom, lightroom k-3 ii, pentax k-3, profile, profiles
Lightroom Camera Calibration profiles for K-5lls djam General Photography 13 11-15-2015 07:08 AM
ACTION NEEDED! Lightroom Profiles for K-3. skyer Pentax K-3 66 07-31-2015 06:55 AM
Adobe lens profiles for Camera Raw, Photoshop CS5, Lightroom 3 knoxploration Post-Processing Articles 108 11-03-2013 12:14 PM
Updated to Lightroom 3.6... Lens profiles disappeared? ElJamoquio Digital Processing, Software, and Printing 4 01-07-2013 09:32 PM
More lens profiles with Lightroom 3.2 final Class A Digital Processing, Software, and Printing 15 09-01-2010 08:12 PM
All times are GMT -7. The time now is 05:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
