07-05-2016, 01:04 PM   #1
First things to do when a new K-3 ii arrives?
Off the top of my head, I believe I should probably do the battery charge to the full. But is there anything I else need to do? Maybe find out shutter counts? firmware update? adjust some settings?
07-05-2016, 01:14 PM - 1 Like   #2
jatrax's Avatar
No new firmware for K-3II AFAIK.
I keep a list of menu items I always change to set the camera up the way I want as I change bodies. So the first thing I do is configure the camera, and copyright info and so on. That way I know how it should respond to the controls, easier to detect something wrong that way.
I suppose the really first thing is just a walk through of all the parts in the box, to make sure everything is there, then a review of the camera functions. Then I setup the menus.
07-05-2016, 01:17 PM - 2 Likes   #3
max_pyne's Avatar
First thing is to go out and enjoy your new tool! ;-)
07-05-2016, 01:29 PM - 1 Like   #4
Mount a lens, insert the battery, turn it on (there should be enough charge for at least a few shots). Make sure all the basics are working - mode change, aperture manipulation, etc. Take a few pictures. Make sure at the very least that it doesn't have to go straight back to the seller for being terminally defective out of the box. THEN charge the battery all the way up and worry about the menus.
While you're waiting for the charge, read the manual unless it's a backup or replacement body identical to one you already own. If it isn't, find out what's changed compared to your old camera. Then go out and shoot the hell out of it as @max_pyne suggested.
07-05-2016, 01:30 PM - 1 Like   #5
stein's Avatar
I upgraded from K-S1 to K-3 II and the first thing I did with K-S1 and now K-3 II was to go through
1 through 6. I downloaded the videos to my hard drive and watching when time permits. Helps a lot.
07-05-2016, 01:56 PM - 3 Likes   #6
QuoteOriginally posted by talkskiwon Quote
First and most important, the battery. (I am at odds with some advice above, but putting a full charge on the battery will not affect your rights to exchange or return to the dealer and is most likely to result in consistent camera behavior.)
Second and almost as important is to take a walk through the user manual. You can download the manual and get started before the camera arrives.
Third would be to run through the suggested settings list on this site:
Pentax K-3 Review - Recommended Settings | PentaxForums.com Reviews
I did not follow all of the advice, but still found it helpful.
07-05-2016, 03:08 PM   #7
QuoteOriginally posted by stein Quote
I upgraded from K-S1 to K-3 II and the first thing I did with K-S1 and now K-3 II was to go through David Hancock's videos 1 through 6. I downloaded the videos to my hard drive and watching when time permits. Helps a lot.
Thank you, great help!
---------- Post added 07-05-16 at 03:09 PM ----------
Thank you so much!
07-05-2016, 04:13 PM   #8
hcc
hcc's Avatar
+1. Well saId.
advice, battery, camera, dslr, ii, k-3, k-3 ii, k3, pentax k-3, settings, videos
Used K-r - how to test when it arrives? Piotrek K Pentax K-r 15 06-18-2016 06:32 AM
What's the first things you do when you go on this site. LeDave General Talk 21 01-16-2016 10:33 AM
K-3 arrives tomorrow - 1st lens to mount? Bunch Pentax K-3 18 03-28-2015 03:09 AM
What should I do when my K-x arrives? noaslplease Troubleshooting and Beginner Help 39 12-29-2010 02:15 AM
Things to Do While Your New K-7 Battery Charges lawsonstone Pentax DSLR Discussion 15 07-23-2009 10:52 AM
All times are GMT -7. The time now is 01:40 AM. | See also: NikonForums.com, part of our network of photo forums!
