07-13-2016, 06:43 PM   #1
Another my maybe-right understanding of APS-C camera vs Full Frame
Hello! I just got a K-3 ii from Amazon with 16-85, and wanted to clarify something of my own understanding before I jump into K-1 too early not even fully using the camera. In my understanding, APS-C is fully capable for wide angle or ultra wide angle as long as the lens I use are capable of providing me the "wide-enough" angle, lets say 12 mm from FF, because the 8mm lens on my APS-C will give me the image just as wide as 12 mm angle with Full Frame body. Do you agree? Pixel-wise, the 24M pixel in 8 mm angle and 36.4M pixel in 12mm are pretty much the same, so as far as I need 12mm FF as my desired angle, there's no need to upgrade to Full Frame for higher pixel density as well? I'm not 100% certain because I literally just started to have some interest in photography. Is there any misunderstanding or additional aspect that I'm missing when comparing FF vs APS-C? Thanks a lot !!
07-13-2016, 06:49 PM - 1 Like   #2
QuoteOriginally posted by talkskiwon Quote
Pixel-wise, the 24M pixel in 8 mm angle and 36.4M pixel in 12mm are pretty much the same, so as far as I need 12mm FF as my desired angle, there's no need to upgrade to Full Frame?
This is incorrect. You would need 36 MP with the 8mm on an APS-C camera to get the same resolution as the 36 MP FF camera with a 12mm lens.
You are right about the field of view equivalence, however.
Full Frame?
FF is inherently better for wide-angle shooting because lenses with the same field of view are generally simpler to make, and will thus have less distortion / more resolution. Plus, you get a larger sensor with either a higher resolution, or lower noise.
07-13-2016, 06:57 PM   #3
[quote/]
[/quote]
Oops, you are right. I made a wrong assumption there. Great advise. Thanks!!
12mm, angle, aps-c, aps-c camera vs, camera, dslr, ff, frame, k-3, k3, lens, mm, pentax k-3, pixel
Full frame lenses on APS-C bodies weaponx525 Pentax SLR Lens Discussion 37 02-13-2017 04:53 PM
Has aps c caught up to full frame? neostyles Non-Pentax Cameras: Canon, Nikon, etc. 27 10-19-2015 05:49 PM
Comparing the image of APS-C to Full Frame. Newtophotos Pentax SLR Lens Discussion 7 10-01-2015 12:29 PM
Full Frame simulation on aps-c camera via ... Pentaxtic Pentax Full Frame 16 01-15-2014 05:06 PM
Field of View, Full Frame and APS-C compared Ole Pentax Lens Articles 5 04-11-2010 06:27 AM
All times are GMT -7. The time now is 03:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
