Reprocessed image. The first is the image. 2nd is a snip from the center at 100%, 3rd is the same snip at 300%
---------- Post added 08-25-16 at 02:54 PM ----------
Originally posted by MikeD running water seemed to come out fine. Am I missing something?
Pixel shift takes four separate exposures each shifted one pixel, so any movement can cause problems.
---------- Post added 08-25-16 at 03:15 PM ----------
Originally posted by jimr-pdx How long were the 4 exposures? Enough blur could even make for impressionist trees, I suppose.
Shutter was set at 1/3, with pixel shift enabled that would be 4 times 1/3. Shooting in Raw only gives me a special raw file with the 4 images included and a file size roughly 4 times larger than a standard raw file. This same shot (non pixel shift enabled) was running around 35 MB, with pixel shift enabled the file size was 116 MB.
Maybe some others that have been using pixel shift can chime in here, but I've had some serious issues with LR and PS processing pixel shift raw files. After the last update, some of the earlier problems were resolved, but it still seems like LR and PS can't handle highly saturated colors, or shadows. My work around has been to go to Pentax UT5 to process and save as a TIFF then do other editing.
