Originally posted by Auzzie-Phoenix It is entirely feasible. Take a bunch of pixelshifted frames and then stack.. but there is always the possibility of getting trails and misalignments due to the time being 4x a normal exposure. You'd almost have to have a decently fast WA/UWA lens. The K-1 would have the best chance in the pentax lineup of making it work vs. say a K-3II or a K-70 just due to the difference in stops. That difference will mean shorter exposure times. But if you're daring, give it a go on one of the other 2 models and see how it works.
Other than the issue mentioned above, I don't see how it would be much if any different than your current stack routine, other than the length of time for the exposure so the workflow probably won't change at all.
Any movement would definitely create problems, however shooting a macro of a totally stationary object should help with that. My thought was to develop in Pentax Utility 5, to take advantage of motion shift, then save a TIFF for stack images.
