10-05-2016, 11:26 PM   #1
Remind me how to set AF.C for BIF
Hello All,
I have just returned from a day out 'shooting' birds, using K-3 II, HD D FA 150-450 ED DC AW and HD DA AF rear converter 1.4x AW, handheld.
I had wonderful opportunities to shoot a Black Kite that spend quite a bit of time cruising around quite close, and quite low.
Reviewing the shots most are rubbish, and I have to wonder if I was just having a bad day or I do not have the best AF.C settings.
The light was excellent, shooting at ISO 400, point exposure, AF mode select 9 (centre), most shots were reasonably exposed at f/8.0 and between 1/1600 and 1/2500, but most were out of focus.
I have been at this for quite a while and try to ensure that I get focus before starting a burst.
I did recently change my AF.C settings, but blowed if I can be sure what I had them set to previously.
The current settings are (C3 menu)
16. (1st frame action in AF.C) 3- Focus priority
17. (Action in AF.C continuous shooting) 3-FPS priority
18. (Hold AF status) 1-off
Could any who do a lot of BIF shooting with reasonable success please comment on these settings?
I know we have been around these traps before but the whole business is a bit inscrutable.
Cheers,
Terry
10-06-2016, 02:27 AM   #2
QuoteOriginally posted by tduell Quote
It is no surprising that you get no sharp shot with your setup. With the rear converter on DFA150-450 , you get to f8, and in that case, you are satisfied with AFS. If you want to do BiF tracking, the AFC settings above are correct, but use the DFA150-450 without TC. I did BiF tracking with K3+DA300 f4+TC, and it works reasonable well, but it is 420mm f5.6, so the K3 is still able to track with 9 center points (27 points not working with the TC).
10-06-2016, 02:21 PM   #3
Hello biz-engineer,
I should have added that with this lens combination I have been able to get many shots in a burst in focus on many occasions, so it isn't the hardware, and why I suspected the settings. A pity I don't have a record of my previous settings so that I can test, but don't want to have to go through all the combinations and permutations.
If you reckon these settings are correct then I must have been having a bad day.
Cheers,
Terry
10-06-2016, 02:39 PM   #4
Canada_Rockies's Avatar
I suggest using single point AF rather than 9x. I have had better luck with that with the K-3 on the back of the not so fast DA 55-300. The better AF modules in the 150-450 just might work better if you can keep the centre spot on the bird. I also use back button AF (setting 2) because once I have a focus on the bird, and stop down a stop or two, I don't have to refocus the lens.
When I use the M 400 and 1.7X I don't even try to AF. The combo is out to f/9.5 or thereabout, and definitely is in a place it doesn't like. I've AF'd the 1.7X on the M 100/4 successfully.
10-06-2016, 03:11 PM   #5
This was discussed recently over in the BIF Photography thread. There were some good tips. I haven't had a chance really try them out but I feel a have a better understanding of the auto focus now. The discussion starts here.
10-06-2016, 04:11 PM   #6
Why do you ask if you know it? Good luck.
10-06-2016, 05:22 PM   #7
Have another read of my initial post...I said I have changed my settings and don't recall what they were, so sought help in getting it right again.
Cheers,
Terry
---------- Post added 10-06-16 at 05:26 PM ----------
QuoteOriginally posted by JimS_256 Quote
Thanks for that link.
Cheers,
Terry
action, af, af.c, bif, bit, cheers, dslr, focus, hd, k-3, k3, pentax k-3, priority, settings, terry
How to set a price for selling your photo. uday029 General Photography 12 06-10-2016 06:30 AM
AF.C behavior of the K-3 II; or, how to make the most of the AF system bwDraco Pentax K-3 3 09-07-2015 02:11 AM
How to Set Time/Date Stamp to Record SteveCon Troubleshooting and Beginner Help 2 08-07-2015 02:18 PM
How many users set the focus point and use AF.S/AF.C? Kricket Pentax K-r 40 11-22-2011 09:51 AM
How to use The Remote Control C set? pcarfan Pentax Camera and Field Accessories 8 04-20-2009 03:02 PM
All times are GMT -7. The time now is 10:52 PM. | See also: NikonForums.com, part of our network of photo forums!
