I have all of my lenses calibrated on my K-3 and K-3II. Remarkably, the adjustments were identical for both cameras, suggesting that both bodies came off the production line with the same AF sensor adjustment (lucky me
Recently, I bought a "new / old stock" Samsung GX-10 (K10D clone), and I've worked out the AF adjustment values for two of my lenses - the FA50 f/1.4 and Tamron 28-75 f/2.8 (obviously I can only have one value set at any time, as the GX-10 / K10D doesn't support adjustments for multiple lenses).
On the K-3, the FA50 requires +2 adjustment, and the Tamron needs -4; while on the GX-10, the FA50 is best at +030 and the Tamron at +090. This confused me a little... it suggests that a +1 increment on the K-3's AF fine adjustment is equivalent to a -10 increment on the GX-10 (ie. the AF adjustments move in opposite directions for each camera)
Does anyone know if this is the case? If I'm correct, I'm hoping I can interpolate my GX-10 AF adjustment values using the table below - at least as a starting point for each lens. It would save me a lot of time...
Thanks in advance
EDIT: I just tried my DA35 f/2.4... On the K-3 it requires -3 adjustment, so I set it to +080 on the GX-10 and it seems to be more-or-less accurate; needs more testing, but it seems to work. I'd still appreciate any feedback, though, to make sure I'm not suffering from "confirmation bias"
