Originally posted by AIW I am looking for the sharpest lenses that are available on the k-mount, if the 16-85 is a good lens, I'll definitely look into it!
Yup, it's a very good lens. If it didn't have a variable aperture it could pretty much be labeled as a star lens, in my opinion.
The list I linked is only for K-mount lenses, but you can indeed expand to other mounts via the buttons on the page.
Originally posted by AIW To be honest, I have no idea, what are the common problems that arise in the K-3, I had read that there was a recall for K3 camera's back when they were relatively new.
There really aren't any major/recurring issues. The K-3 II did have a service advisory due to an improperly-implemented GPS module, but after that was fixed it was smooth sailing.
If your body has a high shutter count, or if it has been subject to abuse, components are more likely to fail with time. It may also be in need of cleaning. Ironically, the most common problem has probably been a sticky shutter button...but you also get the occasional main board failure, shutter failure, etc. that can affect just abut any DSLR.
As for your photos, first of all there's a high degree of JPEG compression which seems to be degrading the image quality. Second, the lens doesn't seem to be too happy to render hot spots, and you're getting low contrast/ghosting as a result. That kind of performance is to be expected of older coatings. You should be able to clean up the shots fairly nicely in post, however.
The first photo looks fine- just a bit soft (likely due to camera shake).
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
