Originally posted by Pixelhdr Here is my take based on the pictures you posted.
1st picture: very slow shutter speed, I assume it was taken hand held. A little bit of camera motion can significantly reduce sharpness. The low contrast scene is not helping either, giving the impression of low sharpness.
Night scenes: aperture (f/22) too small. While depth of field increases with decreasing aperture, diffraction also becomes worse with decreasing aperture. "Best" aperture is typically around f/8. The scenes have large dynamic range. It seems that you exposed for the shadow; the bright areas were over-exposed and hence impression of poor sharpness. You may want to experiment with different exposure time and then process the raw files to bring out the shadow details.
lol, the first photo was actually taken on a tripod.
So, you're suggesting that I use f/8 for night-time landscape shots? Thanks for the advice though, appreciate it.
---------- Post added 11-01-16 at 06:40 AM ----------
Originally posted by othar To achieve correct exposure the camera has to adjust the shutter speed for a given Aperture and ISO (or auto ISO range depending on your settings), therefore it is possible that your shutter speeds are too slow for your focal lens (your first picture has a slow shutter speed for a 50mm lens for instance)
another problem of your cityscapes might be that your aperture is too warrow (f/22) and diffraction reduces sharpness.
In aperture priority, the shutter speed is automatically set by the camera, based on the aperture of the lens, right? In that case, 1/13th was selected by the camera itself. Mind you, the shot was taken wide-open at f/1.4.
---------- Post added 11-01-16 at 06:45 AM ----------
Originally posted by CarlJF 1st picture: shutter speed is way too slow. Unless you have a perfectly still subject, never go below 1/(2 x focal length). And if people on the pictures are not still, don't hesitate to go 2-3 time faster than this. In your picture with the 50mm, this means 1/100 shutter speed or, even better since the guy is obviously not static, 1/200 to 1/300...
But in the light conditions that I took that particular photo in, 1/100th shutter speed would've given me nothing but pitch black.
Originally posted by CarlJF Night scenes: At f/22, the picture will beging to significantly suffers from diffraction. Unless absolutely needed, with most lens don't close more than about f/11 to get the best picture quality.
Understood.
Originally posted by CarlJF Last picture: I guess this was taken wide open, or at least this looks like it. It's probably just a case of a lens softness when used wide open. Solution is either to close it down 1-2 stop, get a better lens, or accept that this lens will not give you perfectly sharp results wide open... Also, even with stabilization, 1/3 sec. shutter speed is pushing it hard and some hand shake blur might be present. I would not expect 100% clear shots Under these conditions. Again, a slightly faster shutter speed would have helped.
Actually, for this particular shot, the camera was resting on the same marble slab as the subject itself and moreover, I always use a 2 second-timer to reduce any chance of handshake whatsoever.
