Originally posted by Larrymc To set your diopter use a prime lens and auto focus on a well defined target then rotate the little wheel just to the upper left of the red LV (live view) button while looking through the view finder till you get the proper diopter focus
Larry
I have found it more reliable to actually remove the lens, half-press the shutter release button to turn on the in-viewfinder data display, and adjust the diopter so that the displayed text is sharpest.The data is supposed to appear sharp at all times regardless whether the lens is correctly focused. Removing the lens avoids any distractions from the scene.
Viewing a scene through the lens to set the viewfinder diopter assumes that AF is dead-on for that lens, when in fact you may need to tweak auto-focus in the menu.
