I've had my K3 for several years, taken 1000's of photos with it and its been a great camera. However, I recently tried to fine tune the AF on my lenses and seem to have a AF micro-adjust that does nothing. I'm wondering if anyone else has had this problem and found a solution (assuming the problem is with the camera and not me being stupid).
I ran a test with my DA* 300mm, the setup was: TAv set at 1/350s, F4 to give an ISO of 140 (outside in nice light). I created a target and placed it at an incline (~45deg) to the K3 at about 8' from the camera (which should be a dof of about 1/2"). Focus was AFS spot aimed at the centre of my target (hatched area). I then changed the AF micro adj to -10, focussed the camera AF and took the shot. I then only changed the micro adjust to +10 without refocus or change to any other parameters and took a second shot.
I expect this to show the plane of focus to move up the photo but both photos are identical - ie no movement of the in-focus plane. I repeated this resetting the AF (option in the AF adjust screen) between changes with no difference and I also repeated this procedure with my DA* 50-135 @ 135mm and also found the micro-adjust changes nothing.
I compared the 300mm shots in Lightroom and attached a screen shot of the comparison which shows both photos with the same slight back-focus. It means that the micro-adjust simply does not work?
Any one else found this - is it me or the camera not behaving properly??
