Originally posted by Smoke665 In reading the manual and other sources it appears that in the dynamic range adjustments for Highlight/Shadow corrections menu, the Highlight reduction, will actually affect/change the raw file, but the shadow correction will not. Can anyone verify this by actual use or reference?
Highlight correction affects the raw file because it essentially underexposes the image (via shutter speed and/or aperture) and just increases the ISO to compensate. Shadow correction is just a post-processing operation on the data itself.
Originally posted by Smoke665 Also, I can find nothing to confirm or refute the High ISO Noise Reduction adjustment will affect/change the raw file, either in the camera manual or from other sources. Anyone care to elaborate???
High ISO noise reduction does not affect the raw file. You will also get better results by applying noise reduction using your own software (i.e. photoshop, topaz) instead of relying on the camera's JPEG output.
Slow shutter speed noise reduction DOES affect the raw file, however, as it effectively takes and extra exposure and subtracts hot pixels from the image.
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
