Originally posted by Grimmus If you use the User settings on the mode dial, make sure to go through and save the AF Fine Adustment setting in the custom menu to each of the user modes you have set up....otherwise, somewhat surprisingly, settings will remain on the default each time you select the user setting again.
I didn't think much of this before because I had done the AF adjustment before I set up my user modes but I remembered it when I calibrated a new lens/camera combination, so I thought I'd clarify on this a little.
The custom setting #26 AF Adjustment to Off / Apply All / Apply One is stored in the User modes, but individual lens adjustments made under "Apply One" are global. If you change the "Apply One" AF adjustment for a lens in any mode, the adjustment for that lens will also be changed in the U1, U2, U3 User modes when set to AF Adjustment - "Apply One".
Initially I thought this would be a great way to have different adjustments for my zoom lens that needs different correction at short and long ends, but it turns out that's not quite so simple. If one of the AF adjustments is near zero you could set one user mode to turn AF adjust off, but my lens needs something like +3 and +6, so it's not an option for me.
