05-11-2017, 04:31 PM   #61
Otis Memorial Pentaxian
photolady95's Avatar
So, the K-3 doesn't have three settings for the switch?
On newer models, like my K-30 and K-50 the switch can be moved to AF.S or C (which means AF.C, and MF.
My K-x only has AF and MF.
05-11-2017, 04:51 PM   #62
jatrax's Avatar
QuoteOriginally posted by Canada_Rockies Quote
On the K-3, the switch is AF, but the display is MF when you have an MF lens attached.
That is correct, but I just tested this on my wife's K-3 and it does not work. As far as I can tell our cameras are set up identically. But it works with the K-3ii and K-1 but not the K-3 and earlier.
So I will guess that one of the changes made at the release of the K-3ii was to change this behavior. People have been requesting it since the k-x was new so I'm surprised Ricoh would make the change and no one noticed. Unless it was a recent firmware change.
---------- Post added 05-11-17 at 04:55 PM ----------
QuoteOriginally posted by photolady95 Quote
K-3, K-3ii and K-1 have only AF and MF on the lever and then an AF Mode button above the lever that lets you select AF.S, AF.C and AF.A using the front wheel.
05-11-2017, 07:50 PM   #63
confusing........
05-12-2017, 08:42 AM   #64
jatrax's Avatar
QuoteOriginally posted by donlass Quote
confusing........
How so?
06-01-2017, 02:42 AM   #65
QuoteOriginally posted by johnyates Quote
Works fine for me with the K-5.
Note - to use screw mount lenses, you need to short out the camera contacts to get CIF to work.
this was the answer i needed
06-01-2017, 03:44 AM   #66
altopiet's Avatar
QuoteOriginally posted by niceshot Quote
Cut out shim from soda can...very thin
06-01-2017, 10:56 AM   #67
panonski's Avatar
QuoteOriginally posted by bobbotron Quote
There's so much confusion about how to make this work. I really wish on new cameras Ricoh would make it a really clear option, either in the af/mf control on the camera body, or through a menu setting.
aGREE... I'm surprised they did not solve that already... I was in that ship too... Very hard to get this right specially when you have different lens... This option is almost not usable ...
06-03-2017, 06:01 AM   #68
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
QuoteOriginally posted by altopiet Quote
A shim will affect infinity focus, besides there is a simple way to make your camera body think all mounted lenses have an 'A' contact. The link below is to an old post for a K-r, but it works exactly the same way on my K-30 and K-3-
Short the 'A' contact
If your K-3 doesn't give you an aperture range wide enough to cover the actual range of the lens, you might need to go the next step and artificially set your lens' aperture range-
Set the M or K lens aperture range
I did the above as a method for using inexpensive extension tubes that don't carry the lens aperture coding back to the body, but I've also used it when directly mounting a K lens to my camera.
06-03-2017, 06:42 AM   #69
altopiet's Avatar
QuoteOriginally posted by JimJohnson Quote
I'm sure you've tried it. My Tak 55 1.8, Cunor 200 4.5, Cunor 400, Yashinon 50 1.7 etc must be defective, because they don't agree with your assessment
af, af.c, af1, button, cable, camera, change, cif, da, dslr, fa, focus, k-3, k3, k3ii, lens, lenses, macro, mf, pentax k-3, post, press, release, shutter, switch, tc
Macro Beating the heat charliezap Post Your Photos! 7 08-26-2018 07:03 PM
Nature More Dead Leaves - sorry :-( tessfully Post Your Photos! 15 03-14-2013 08:18 AM
sorry to beat a dead horse k-5 kit??? no694terry Pentax SLR Lens Discussion 20 02-07-2013 08:14 AM
Beating a dead horse DA15mm vs 12-24mm zoom Jeff Bennett Pentax SLR Lens Discussion 19 03-04-2011 11:22 PM
I almost feel sorry for him...almost. jeffkrol General Talk 32 06-21-2010 11:20 AM
All times are GMT -7. The time now is 02:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
