05-20-2017, 01:09 PM   #1
K-3 II Panning Shake Reduction
There have been quite a few threads discussing K-3 & K-3 II AF performance; but I'm interested in one particular aspect: panning.
Background - I shoot motorsports fairly frequently, and love slow (<1/80) shutter speed panning shots. I'm currently using a K-5, and more often than not, a 60-250mm that I prefocus. I generally fire a short burst, and my keeper rate is...OK.
I'm pondering the upgrade to either a K-3 or a K-3 II. I've weighed the other differences; but none are as potentially important for this use case as the shake reduction while panning.
So, for those who also shoot fast-moving objects, man-made or otherwise, do you think the panning SR is good enough to tip the scales in favor of the K-3 II? How effective is it in the real world?
05-20-2017, 07:47 PM   #2
I wasn't aware any Pentax had SR dedicated to panning? There is no option for vertical or horizontal stabilization. I may be wrong here but i think you should be turning SR off while panning.
05-20-2017, 10:02 PM   #3
QuoteOriginally posted by bschriver11 Quote
It's a first for Pentax. When it detects panning, it shuts down stabilization along the axis of motion, and maintains it in the other axis. From the Imaging Resource review:
"At the same time as improving the efficacy of the stabilization system, Ricoh has also made another change which should mean that you get better results when shooting moving subjects: The Pentax K-3 II's Shake Reduction system can now detect and account for panning motion, stabilizing your motion on all but the axis of the panning motion."
Pretty trick, no?
05-21-2017, 06:06 AM   #4
JCCharles's Avatar
I had a K7 then I recently got the K3ii. I also do quite a bit of motor sports photography and it's panning detection works well. On the K7, I had to turn the SR off in order to get clear panning shots as the SR was countering the panning, making the image significantly worse. When I would take my people shots, I would forget to turn it back on, another issue. With the K3ii, its no longer the case. On top of that, I can take panning shots handheld, which I couldn't do before. The panning detection doe work and it works well!!
05-21-2017, 08:47 AM   #5
jpzk's Avatar
QuoteOriginally posted by ephophex Quote
Does it work the same on the K3 ?
05-21-2017, 08:58 AM   #6
the 8+ FPS will likely do more for your images than the shake reduction. i use a k3 and shoot motorcycle racing constantly. rarely go as slow as 1/80 but do a lot at 1/125.
as far as i know the k3 doesn't have panning shake reduction, so it must be a k3ii thing?
05-21-2017, 10:29 AM   #7
JCCharles's Avatar
I believe the panning SR is part of the upgrade from K3 to K3ii. The other upgrades are the GPS (which replaced the built in flash), AstroChaser mode and pixel-shift high res setting.
05-21-2017, 10:57 AM   #8
QuoteOriginally posted by JCCharles Quote
Thanks, JC!
I'm the world's most absent-minded shooter; so simply not having to remember to switch it is a huge plus.
dslr, ii, k-3, k-3 ii, k3, pentax k-3
K-3 II Shake Reduction effectiveness tduell Pentax K-3 22 03-08-2016 01:49 PM
K-3 vs K-3 II Shake Reduction mee Pentax K-3 11 12-02-2015 04:53 PM
K5 II video shake mechanical or electronic shake reduction? Rice Pentax K-5 3 06-14-2014 02:51 PM
Shake Reduction while Panning SDShooter Pentax DSLR Discussion 5 09-27-2009 10:43 AM
shake reduction + "panning" nanok Pentax DSLR Discussion 38 05-25-2009 08:49 AM
All times are GMT -7. The time now is 02:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
