So, on June 12, I shipped my Pentax K-3 II to Precision Camera for a repair due to AF problems: it was wildly inconsistent and could not be relied on to produce consistently sharp images. For several months, I thought the problem was my D FA* 70-200mm (and went through several major assignments with this issue), but realized that the camera was at fault when I found that my DA 18-135mm could not focus reliably either. Less than two weeks later, the camera came back from repair, and preliminary tests with my 70-200 show that the problem is indeed solved. A +3 adjustment was required for focusing accuracy, but it's no longer focusing way off 60-80% of the time like it used to.
Quote: CALIBRATED AUTO FOCUS
A COMPLETE REPAIR AND RETURN ALL FUNCTIONS TO FACTORY SPECS.
AUTO FOCUS TEST, CHECK, RECALIBRATION, AND REALIGNMENT
GENERAL TEST, CHECK, CLEAN, AND REPAIR ALL FUNCTIONS AND SYSTEMS
COMPLETE CLEANING (INTERNAL-EXTERNAL) AND OPTICAL SYSTEM
The camera was under extended warranty.
Questions, thoughts, or comments?
Draco
