Originally posted by Prakticant Might be the ISO 'climbing' mode (slow, standard, fast) do influence the results in TAv mode, so users forum is interesting place to share the thoughts (but nobody suggested that influence?).
That feature has a strange history on this site with at least one user (me) having a misconception based on various sources. The options are misnamed and documented incorrectly, but at the risk of not remembering right, I won't attempt to recall without finding the definitive thread on the topic. (I believe the settings influence the start point for the ramp and nothing else.)
Normally the auto-ISO settings don't come into play in TAv mode, though I believe they might when flash is attached. At least that is how it looked when I tested it this evening.
BTW...you must have been in a seriously dark room and/or impressive distance to have the ISO ramp above 10,000 with P-TTL flash in TAv mode.
Originally posted by Prakticant Usefulness of Pentax/Ricoh DSLR technology: no sports (slow focussing), no children (slow focussing), no portraits/shallow DOF (front/back focussing), no usable flash (P-TTL), no weddings (1/3 sec shutter delay), no standard zoom (don't call 2.8/15-50mm a DA* lens - I got two different source equal rubbish).
Great system for sunny days, but why not to shoot Lomo then
Sounds like you are a good candidate to switch brands. My suggestion would be Nikon. They have superb flash system integration and top-tier AF. You will also be doing your part to save a struggling company. One caution however, even Nikon will not automatically do predictably consistent fine/selective focus for portraits.
Originally posted by Prakticant OK, I'm frustrated
Actually I'd like to learn how it compares with Nikon/Canon/Sony fill-in low light flash photography?
All are P-TTL and the tech is very similar across brands. I would suggest addressing your "pain point" of low-ISO, low-light fill-flash* with a try at using manual or semi-automated technique with your Pentax before putting too much blame on the camera/flash system. Example:
- M-mode (chosen because P, Sv, and Av tend to keep shutter speed at 1/80s or higher making flash-as-fill difficult)
Edit: @mgreni made the suggestion of using the Slow Sync feature. Doing so allows the camera to drop the shutter speed when using AE in low light conditions. - Manual ISO 800
- LV 4 (moderately dimly lit room)
- 10ft
- P-TTL (-1 EC as fill)
Notice that I defined LV (Light Value) instead of aperture/shutter. That was intentional because I wish to test the ability of P-TTL to attenuate with both the on-board flash and my Sigma EF 610 DG Super.
- f/4.0, 1/8s both on-board and the Sigma attenuated beautifully
- f/2.0, 1/30s (same LV) on-board was fine, but the Sigma overexposed by at least two stops
We've got problems. Generally, 1/8s is too slow for flash shooting because of the risk of ghosts and in this case, 1/30s results in too wide an aperture for the more powerful flash to deal with at that distance. Solutions might include increasing the ISO to allow a narrower aperture and higher shutter speed or bounce the flash off the ceiling to spill some photons or a diffuser/filter or full manual flash (strobist technique) or any number of other tricks.
Good luck! FWIW, I am not a huge fan of P-TTL.
* In case anyone cares, true fill flash in low light is difficult, both from an aperture and shutter speed point of view. The ambient light exposure must be appropriate to the available light and the flash portion must be scaled down to allow the ambient light to dominate. The two requirements are at odds with each other.
