Guys, if you say '
manual' flash mode, please be precise, as there are at least three different flash manual modes with
Pentax K-3 and
Pentax flash:
* on_the_flash manual mode (
from 1/1 down to 1/64 flash power);
** camera program manual mode (
Av, TAv, M = manual, B, X, ...);
*** camera menu Manual Flash Discharge mode (
the one you find under down four-way joystick controller) from 1/1 down to 1/128 flash power.
Some of the above modes override the others, some influence other camera settings (
mostly allowed shutter speeds, i.e. 1/180 or 1/90 as the shortest sync time, with the latter not feasible for long focus/tele lenses).
Actually, I doubt there is any manual mode with HSS or with trailing (
second) curtain sync.
To mess things up, it looks there is some incompatibility between at least
Pentax K-3 body and
Pentax AF-540FGZ (
ver. I) flash unit, as even with on-flash selector set to last fourth
HSS setting, camera quite often disallows shutter speeds shorter than 1/180 sec. - or I do not know how to operate it to get into
HSS mode whenever I want (which I doubt - as solved by switching-off both units, separating them, taking-off both batteries, than assembling again, then
HSS mode (
shutter times shorter than 1/200 sec.) comes back as accessible
Good news:
In the meantime I found out some workaround how to learn an
ISO when in
TAv mode.
Press '
MODE' on your
Pentax AF-540FGZ strobe as to get into flash '
SB' (
Spot Beam) mode, than '
Auto' (
ISO) reading on your
K-3 dissapears and you see an ISO value which
K-3 chooses for the ambient light.
Pressing the on-strobe
MODE button is much simpler than switching-off that flash.
Originally posted by mcgregni a typical outdoors set up for me is ambient exposure -0.7 stops, flash exposure +1.0 stop.
You go strange way
as my (
and other people I know) flash exposure compensation always goes minus (
-0.3 down to -5.0 with very close distances), but may depend on the strobe unit (
i.e. Sigma tends more to overexpose than Pentax).
Originally posted by photoptimist (by not setting a tighter AUTO-ISO range)
Too simple answer.
Might be the camera menu 6.
Auto EV Compensation '
On'?
