Originally posted by gaweidert 1/2000 sec should just about freeze and camera movement
yes and no.... SLR cameras with a mirror for the optical viewfinder, with few exceptions, use a focal plane shutter. A focal plane shutter has two curtains, leading and trailing. Exposure to any part of the sensor or film is based on the amount of time a gap between the two curtains takes to pass over that part of the sensor or film - - however, it is a misconception that the
entire exposure takes that amount of time. In actuality, at shutter speeds higher than X-sync, the
entire exposure always takes the same amount of time and is equal to the shutter's X-sync speed. With the K-3, that is 1/180th of a second.
At 1/2,000 the gap between curtains is very small indeed. Individual pixels in general are frozen. However, an object moving perpendicular to the direction the curtains travel still has up to 1/180th second of motion across the entire exposure. This is why panning is often still necessary at higher shutter speeds to minimize subject distortion. And Shake Reduction can add its own funkiness to an image shot at high shutter speeds depending on how it interprets the camera movement.
