Originally posted by bobbotron Agh, that is confusing. I'm a software developer by trade, this sounds like something I would do before testers remind me of how there's a better way. :P
So if I set the interval to 15 seconds, and my shutter to 15 second exposures... it should take the number of shots equal to the "number of shots" setting?
---------- Post added 12-14-17 at 05:02 PM ----------
Ps, thanks for the help and the tip on the NR setting!
Actually, you might need an interval of maybe 17 seconds for a 15 second shutter time (or maybe 32 seconds if slow-shutter NR is enabled).
Although the system seems stupid, it's the only way to ensure accurate control of the shot spacing which seems to be the whole purpose of intervalometer. And it's the way film camera mechanical intervalometers worked. If you really want EXACTLY 60 pictures per hour for a time lapse, then you don't want the intervalometer measuring time relative to when the camera is ready for the next shot (which varies with shutter speed in P, Av, and Sv modes, in-camera processing, as well as with the complexity of the scene and any thoughtput variations on the SD card). Timing the intervals to the camera's readiness would create uneven intervals.
This is one of those nasty software design situations where both ways are wrong or have nasty unintended consequences that irritate or befuddle the user.
