Originally posted by mfedley To be explicit, my VERY old Kr has a sharper and brighter image through the viewfinder than my newer K3 (focus can be made slightly better when playing with settings - does not affect the brightness of image through the viewfinder though).
This is not normal, as youʻve suspected, as the Kr uses a smaller, less bright pentamirror compared to the K3 larger and brighter pentaprism.
If you can see a significant reversal of this, then something is amiss with your K3 pentaprism that needs repair unless youʻre willing to always use Live View. The pentaprism is a solid piece of glass, and the off-centering and dimmer view seems to suggest that the glue or foam that seats it has become dislodged and needs to be repaired.
This can happen by physical impact, environmental shock (extreme changes in heat and humidity), or a manufacturing issue that is manifesting itself now. Probably a combination of events, which in my experience is rare.
