Show Printable Version 4 Likes Search this Thread
04-22-2018, 11:53 AM   #16
Otis Memorial Pentaxian
QuoteOriginally posted by Larrymc Quote
Steve the K-3 will retain the offset if camera menu 4/memory is checked.
It will retain between live view sessions, but not on a move out of live view.
04-22-2018, 01:10 PM   #17
Alex645's Avatar
QuoteOriginally posted by mfedley Quote
When a photo is taken, the object moves to the left. This does not happen in live mode. There is no problem with exposure of sharpness.
If you have a tripod, ʻlock it downʻ (so it wonʻt move) and run a test with a stationary scene:
1) With your Pentax 18-135mm at letʻs say 100mm using the optical view finder.
2) The same as above with Live View.
3) With your Sigma with the optical view finder also at 100mm.
4) The same as #3 but with Live View.
Is #1 still shifting to one side? Or is #1 and #3 shifting to one side?
04-22-2018, 02:06 PM   #18
Seeker of Knowledge
aslyfox's Avatar
if the OP doesn't have a tripod, the same experiment might be done if the camera body can be placed on a solid object as opposed to trying to hand hold the camera and lens
correct ?
04-22-2018, 02:14 PM   #19
Alex645's Avatar
QuoteOriginally posted by Aslyfox Quote
correct ?
Sure, but he really wants to make sure it isnʻt sliding/panning at all, so then use a pillow, cushion, bean or rice bags...just make sure it doesnʻt shift or move between changing lenses. Or put some tape on the wall or table to make sure the alignment remains the same.
04-22-2018, 02:16 PM   #20
Seeker of Knowledge
aslyfox's Avatar
good points for sure
I only thought that not everyone has a tripod
[ and the OP is too far away for me to loan him one of the several i have ]
04-22-2018, 02:33 PM   #21
Larrymc's Avatar
Nope, just checked it and even turned the camera off. When I went back into live view it showed my setting of 10 to the left. There is a setting in the camera menu 4/memory/2/Live View that if checked will retain the off-set settings if you press the OK button after doing the off-set in Live View. Give it a look. I'm not sure what value it is, although my K-3 Live View center of focus is slightly off from my View Finder red dot. I might try that to match up the focus points better
Larry
04-22-2018, 03:19 PM   #22
dbs
Hi mFedley
What the lens and film/sensor see"s has best to my knowledge has always been different to the viewfinder.
Is this what you are seeing" So you get more than you thought when viewing the picture.
Dave
04-22-2018, 03:43 PM   #23
Alex645's Avatar
QuoteOriginally posted by dbs Quote
Hi mFedley
Dave
On the K3, the optical viewfinder is supposed to be 100% coverage albeit .95x magnification. This is not the case on all DSLRs, but is typical specs on a flagship model. (For example, the K-r had a pentamirror with 96% coverage and .85x magnification.)
As I understand the OPs concern: With one lens only, there is a shift to the left relative to his OVF on the recorded image.
04-22-2018, 08:27 PM   #24
dbs
Hi Alex
I went for the easy option,others have mentioned a technique problem or camera setting problem.
Yes I am usually wrong.
Dave
04-22-2018, 09:00 PM   #25
Alex645's Avatar
Hi Alex
Dave
Dave, heck as far as I know, weʻre all wrong, or we could all be partially right too. I appreciate these puzzlers and everyoneʻs ideas. Ultimately, when the OP runs some "proper" tests, we can by process of elimination narrow down the cause.
If I had a dollar for every right answer vs. wrong guess, Iʻd be in debt.
04-22-2018, 09:08 PM   #26
dbs
Hi Alex
Whehw then I am not alone
After re-reading the OP"s post I reckon his" stock lens" is playing up.
Dave
04-22-2018, 10:41 PM   #27
I guess that means that I didn't check mine, except that photographic evidence says that I did.
04-23-2018, 12:03 AM   #28
Hi mfedley
I just purchased a K3 II this last week. While I have been getting familiar with it I was having a similar problem to what you described. As it turns out I was having a difficult time looking thru the view finder with my bi-focal glasses on. As soon as I viewed without any glasses on, the problem went away.
Do you wear glasses or have you had a new prescription lately? If so this might be part of the problem.
Good Luck
04-23-2018, 03:15 AM   #29
Hi All,
First thanks for all of the info and I've completed a bit more experimentation on it now that I'm not so tired. Some of my original comments were actually incorrect now that I have completed more experimentation. I'll state what my problem is, along with what equipment I have, what I have tested and what the results where.
Original Problem: Viewfinder and photo do not match up. Viewfinder photo seems to be 10% to the right. Occurs on K-3 18-135mm stock lens. No problems when using Live Mode
Equipment for Experimentation: Pentax K3, Pentax Kr, Pentax 18-135mm lens, Pentax 18-55mm lens, Pentax 55-300 lens, Sigma 18-250 lens
Pentax K3 + 18-135mm lens: The photo DOES move 10% to the right. It is fine in LIVE mode. However, I can hear something moving when it is in live mode but it locks into place when using the viewfinder.
Pentax K3 + Sigma 18-250mm lens: The photo DOES move 10% to the right. It is fine in LIVE mode. However, I can hear something moving when it is in live mode but it locks into place when using the viewfinder.
Pentax Kr with 18-135 mm lens: no problems.
Pentax Kr with Sigma 18-250mm lens: no problems.
MAIN COMMENT: When I use the 18-135mm lens and Sigma 18-250mm lens in LIVE mode I hear movement when I move the camera slowly back and forth. Could it be that the viewfinder mirrors are potentially jiggling around??
Pentax Kr with 18-55 & 55-300mm lens: no problems
04-23-2018, 06:28 AM   #30
Larrymc's Avatar
Hi All,
So the the frame off set is OK? What you are hearing in live view is probably normal operation of the K-3, mine does it too, stop worrying about it and take photos!
Larry
camera, composition, composition adjustment, couple, dslr, k-3, k3, k3 stock lens, larry, lens, live, menu, months, pentax, pentax k-3, pentax k3 stock, photo, questions, singapore, steve, sunday, view, viewfinder
Where in EU to get an K-3 (new) body only (old stock/final stock...) Pentax_SLO Pentax DSLR Discussion 10 10-18-2016 05:40 AM
Stock un-shimmed focusing screen, a problem? pentax360 Pentax DSLR Discussion 7 01-25-2016 10:18 PM
K3 II Stock - Clean Serial Numbers Yet? RustyToyotaVT Ask B&H Photo! 2 08-19-2015 03:36 PM
K3 silver back in stock jerryleejr Pentax Price Watch 8 05-30-2014 12:26 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 & K-5 II 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 10:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
