This
article from 2015 recommends some cameras for astrophotography. The authors mention the K-3II but admit they never used one. Concerning it they say,
Quote: ...at high ISOs noise levels are slightly worse than with the [Canon] 70D, and certainly worse than the [Nikon] D7200. Noise is on par with the Canon D750/760 (sic) models. OK but not the best.
They don't reveal what data they looked at to arrive at those conclusions. They also don't say what kind of noise they are talking about. It can't have been read noise since the published data I have seen on that says that the K-3 and K-3II are considerably better than the 70D and 80D (the 70D's successor) at almost every ISO value.
Nor do their conclusions match the data at the
Sensor Noise DB, which is the only source of data I have seen on thermal noise during long exposures (30 seconds and greater). That data says that the D7200 has worse thermal noise than either the 70D or K-3 (no data on K-3II in the DB), which contradicts one of the statements quoted above. However,
Roger Clark claims
here that Brendan's measurement methodology is seriously flawed and can't be trusted.
So, some questions:
(1) Is there a source of reliable data on thermal noise of cameras over long exposures (aside from the questionable Sensor Noise DB)?
(2) Which camera models are comparable to the K-3II in terms of thermal noise over long exposures?
Answering (2) without resorting to opinion would seem to require that there be an answer other than "no" for (1).
