Originally posted by MrEarle I have a 1920 x 1080 monitor
That is inadequate real estate for photo editing in that it is too small to support both the editor and the photo being worked on.
Edit: I gave this a bit more thought. I have a 24" monitor running at 1920x1200. 1920x1080 is not that much smaller and is spec'd 16:9 format presentation, meaning that it is a common size. I booted my main workstation and compared working in LR both with and without the extra 120 vertical pixels. What resulted was a significant loss of both height
and width with the image window set to "fit". My impression is that while 1920x1080 may be adequate, having a little more real estate is of significant benefit.
/Edit Originally posted by MrEarle at 100% can only see sections of the full image at 100% - and it's grainy, not pixillated, grainy like a 35mm negative blown up over 16x20.
Very few monitors are capable of showing an entire K-3II image at full resolution within an image editor. That is not a problem, however, since very little of your editing (almost none) is done at full resolution and most tools allow easy navigation to the areas of interest when at that setting. As for "grainy", you may be seeing noise. Even at base ISO, there is always some.
Originally posted by MrEarle I'll just have to do some A/B comps and use the DCU and see what gets to the printer...
What is on the screen as best effort in editing and what comes out of the printer may be somewhat different...just a heads-up Most good image editors will provide a reasonable print from within the editor if printed to glossy or semi-gloss photo paper. The most common issue being that prints are often too dark. Printing to specialty papers requires some skill and special technique.
